(2016-10-14, 13:50)telexxingou Wrote: [ -> ]Hello....
Just me or something has changed.....today...
On Kodi beta 3 + script.tv.show.next.aired (6.0.15) i don't get anymore some episode information in ListItem.Property ....
NextTitle, NextDate,.......gone....
tested on some skins, same result
tv.show.next.aired window guide work nice with all information....
but inside other windows(dialogVideoInfo for example), don't work anymore.....
Worked 2 days ago....
Works perfectly for me using latest nightly and Rapier skin.
(2016-10-14, 17:33)Gade Wrote: [ -> ] (2016-10-14, 13:50)telexxingou Wrote: [ -> ]Hello....
Ok thanks....i'll check here...
my problem was skin.helper.service 1.0.115 ....back to 1.0.100 and work again
(2016-03-12, 23:30)dnlg Wrote: [ -> ]Wonder if anyone can help me. All schedule's are show up a day after it's suppose to. Shows that air On Monday are showing up as Tuesday. Tuesday are showing up as Wednesday and so forth. I don't know what I did wrong. Can anyone help?
I am having the same issue. My system clock is set correctly.
Love this app! Unfortunately, my Fire TV Stick completely died. I was using Amber, and this app worked great. Now I have a Fire TV running Estuary, and it doesn't work; nothing displays. I've also tried it with the same Estuary skin on a Galaxy S5 device, and same problem. I can't figure out what setting I might be missing. Any suggestions?
Thank you!
It just occurred to me that I'm now only using Trakt for my collections/lists. Does Next Aired recognize that database? When I had it working on my previous system, I had library integration, however, I don't believe Trakt is integrated into the library. Could this be the issue?
Hey, is there anyway someone could add support for trakt personal collections (TV Shows, New Movies and New HD/Blu Ray movie releases) to display in TV Show Next Aired?
Next Aired displaying TV Shows a day ahead
A great job.
I have a question, in the configuration section, advanced options, language search in TVDB, if you select SPAIN / SPANISH ...
1. Is this selector from Spain or Mexico?
2. Choose the country.db you choose, always load the information from USA, is this normal?
Thank you very much.
In case this is the normal operation of your script, what would you have to do if you upload the information of Spain that is the one that interests me?
(2017-02-07, 21:04)Blurayx Wrote: [ -> ]Next Aired displaying TV Shows a day behind
A day after on my setup. Next aired episodes and previous episodes.
(2017-02-10, 01:23)gorx76 Wrote: [ -> ] (2017-02-07, 21:04)Blurayx Wrote: [ -> ]Next Aired displaying TV Shows a day behind
sorry, I meant to say a day ahead
I hope the bug can be fixed
(2017-02-10, 03:43)Blurayx Wrote: [ -> ] (2017-02-10, 01:23)gorx76 Wrote: [ -> ] (2017-02-07, 21:04)Blurayx Wrote: [ -> ]Next Aired displaying TV Shows a day behind
ED1T2:
idk about this.
Id really like to be able to call this from the context menu to see the status of any particular show (whether it's cancelled, how many seasons, etc) if I'm browsing say from a trakt list before I put something in my library. If this isn't suitable, does anyone know how to accomplish this?
Sent from my ZTE A2017U
If I use Language of Traditional Chinese, the Date would not be shown, no problem in English. Any setting I need to do? Thanks!
When use the Traditional Chinese, cannot show the Weekday, Today, Tomorrow and Month
No problem in English
