Hi Wayne,
I'm finding some shows that I've deleted from Kodi are still showing up in next aired, is there a way I can delete them? I've deleted the empty folder but its its still showing up in next aired, one of the shows btw is Brooklyn Nine nine.
(2017-12-06, 17:34)startreksteve Wrote: [ -> ]Hi Wayne,
What version are you using?
(2017-12-09, 05:40)Blurayx Wrote: [ -> ] (2017-12-06, 17:34)startreksteve Wrote: [ -> ]Hi Wayne,
whats the latest dev version for leia?
Has this Addon died?
First post in this thread last updated 2014-05-04
Last Github update - Dec 28, 2015
WayneD last visit - 2017-02-26.
(2017-12-24, 16:45)eddiem Wrote: [ -> ]Has this Addon died?
It still works, if you want an "updated" version with less features you can use Marcels one
https://github.com/marcelveldt/script.tv...next.aired
(2017-12-24, 16:49)komplex Wrote: [ -> ] (2017-12-24, 16:45)eddiem Wrote: [ -> ]Has this Addon died?
It still works, if you want an "updated" version with less features you can use Marcels one https://github.com/marcelveldt/script.tv...next.aired
personally I prefer the old version because It syncs to my Timezone.
(2017-12-24, 17:44)Blurayx Wrote: [ -> ]personally I prefer the old version because It syncs to my Timezone.
Same, can also omit shows which you can't do in the updated one
(2017-12-24, 17:47)komplex Wrote: [ -> ] (2017-12-24, 17:44)Blurayx Wrote: [ -> ]personally I prefer the old version because It syncs to my Timezone.
I've requested a Timezone shift option. a few weeks ago, I'll try again in the new year.
https://github.com/marcelveldt/script.sk...issues/112
How do you omit shows? cant find the option in either version?
Steve
(2018-01-15, 17:59)startreksteve Wrote: [ -> ]How do you omit shows? cant find the option in either version?
Steve
Its in the settings menu at the bottom, you can add upcoming shows as well, though I confuse all the versions
Though I was wondering how to add more then one show? I assume with a , or a / Do we add a number, then a comma..then space then new number?
This addon stopped working all of a sudden. It is not showing any shows in the list.
And gives an error sometimes.
I've checked the log and it says there is something wrong with the date.
Error contents: year=1017 is before 1900; the datetime strftime() method require >= 1900.
I'm running this on shield and my date and time are correct.
Has this been abandoned? This doesn't seem to run in Leia.
Working just fine on Leia for me.
(2018-04-19, 00:56)Hitcher Wrote: [ -> ]Working just fine on Leia for me.
I can't get this to run in Leia using Estuary skin. Does it need companion addons?
Which version are you using and what skin?
