So far, All the fixes in this thread have helped fix the issues I've been having. Accept for one. I'm still not getting the correct time for shows to air. Ex: S.W.A.T. airs at 10:00pm EST for me here in the U.S.A. But, It's displaying the air time as 2200. Technically, that is 10:00pm, if I were using a 24 hour clock, which I'm not.
Does anyone know of a way to fix this, so that it shows my local air times using a 12 hour clock?
p.s. Thanks to all who have contributed to all the fixes in this thread.
Is this add-on currently affected by the TVDB 'outage'? None of my shows display next air date anymore.
It aborts due to fetch failures.
(2019-11-18, 07:20)Cinephile Wrote: [ -> ]Is this add-on currently affected by the TVDB 'outage'? None of my shows display next air date anymore.
Yes, I have the same issue. hopefully, it will be fixed soon.
I am assuming that the updated metadata.tvdb.com-3.2.0 does not fix the issue of the TV Guide (TV Show Next Aired) not updating? I couldn't find any info regarding this on the following
https://forum.kodi.tv/showthread.php?tid...pid2901564 TVDB links.
Sorry if I missed it.
Shedrock
(2019-11-20, 02:03)shedrock Wrote: [ -> ]I am assuming that the updated metadata.tvdb.com-3.2.0 does not fix the issue of the TV Guide (TV Show Next Aired) not updating? I couldn't find any info regarding this on the following https://forum.kodi.tv/showthread.php?tid...pid2901564 TVDB links.
Shedrock
I don't see anything either regarding TV Show Next Aired. I'm sure its TVDB data related
I just updated from version 6.0.15 to version 7.0.1 and then performed this edit:
in "addons\script.tv.show.next.aired\resources\skins\Default\720p"
EDIT FILES:
"script-NextAired-TVGuide.xml"
"script-NextAired-TVGuide2.xml"
replace all "StringCompare" with "String.IsEqual"
I restarted KODI and it works now without any fetch failures!
(2019-11-20, 17:17)melons2 Wrote: [ -> ]I just updated from version 6.0.15 to version 7.0.1 and then performed this edit:
EDIT FILES:
Unfortunately that would not work for me. I tend to stick with the Kodi repo versions. If I don't then I can't use all the other "non-modified" skins. It messes up the Episodes Airing Today widgets.
Shedrock
EDIT FILES:
I do not see any mention of “stringcompare” in either of those xml files.
I found it. I’m blind lol
(2019-11-20, 17:21)shedrock Wrote: [ -> ] (2019-11-20, 17:17)melons2 Wrote: [ -> ]I just updated from version 6.0.15 to version 7.0.1 and then performed this edit:
EDIT FILES:
Shedrock
shedrock
I find 7.0.1 very buggy. The main reason I don't use it. 7.0.1 does not identify most of my TV shows.
(2019-11-20, 22:10)Blurayx Wrote: [ -> ]@shedrock
That's exactly my issue TBH. I use the Kodi Repo version with Aeon Nox Silvo, Amber and Aeon MQ7 (Latt's Mod), but with the Aeon MQ7 skin I had to modify the IncludesVariables file in order for the TVShow Next Aired to work. If I use v.7+, nothing is accurate in terms of my widget display.
Shedrock
I am confused. If I can't update the TV Guide, then how come I just did a fresh install of Kodi (Leia) on my Windows box and it is showing up to date episodes airing today on my widgets (Aeon Nox Silvo) skin? It only shows one show airing today on my LibreELEC box. Maybe someone can enlighten me on this?
Regards,
Shedrock
(2019-11-21, 03:13)shedrock Wrote: [ -> ]I am confused. If I can't update the TV Guide, then how come I just did a fresh install of Kodi (Leia) on my Windows box and it is showing up to date episodes airing today on my widgets (Aeon Nox Silvo) skin? It only shows one show airing today on my LibreELEC box. Maybe someone can enlighten me on this?
Regards,
Shedrock
In latts mod MQ7 are you using widget: "EPISODES AIRED TODAY" or "EPISODES AIRED TODAY (NEXT AIRED)".............?
Is there anything besides choosing the widget to make it work?
Thank you
By the way.........you are right V. 7.0.1 too buggy back to 6 and waiting!
Regards,
Shedrock
I noticed that a few days ago, episodes airing dates showing on my Arctic Zephyr 2 widgets
