2019-11-24, 18:54
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75
2019-11-24, 18:54
2019-11-24, 19:18
(2019-11-24, 17:56)Blurayx Wrote: [ -> ]@shedrockI currently have 3 episodes showing today. His Dark Materials, One planet seven worlds and Watchmen. I know there are more TV Show episodes airing today as well, but the TV Guide is still not working. I also have 3 shows that interrupts the update or reset process in TVshow Next Aired. They are Sons of Anarchy, BBC Documentaries and Lark Rise to Candleford. If I remove those, then it updates, but it really doesn't update anything.
Did you get your Next Aired working?
Shedrock
2019-11-24, 19:25
(2019-11-24, 18:54)ShadowTek Wrote: [ -> ](2019-11-24, 17:56)Blurayx Wrote: [ -> ]@shedrock
Still same issue for me, just for general knowledge
Next Aired is working great for me with the temporary fix.
After applying the fix before “Reset all data”. I deleted the files in userdata/addon_data/script.tv.show.next.aired.
it may work for you.
2019-11-24, 19:32
(2019-11-24, 19:25)Blurayx Wrote: [ -> ]Next Aired is working great for me with the temporary fix.But that folder only contains (2) files. settings.xml and the DB file, which gets written over on a reset anyway, so removing them wouldn't make any difference because it is not a cache file you are clearing. Anyway, I tried it and it still doesn't work for me.
Regards,
Shedrock
2019-11-24, 19:40
(2019-11-24, 17:00)Blurayx Wrote: [ -> ]update:Metadata.tvdb.com-3.2.1And where should these files go?
http://mirrors.kodi.tv/addons/krypton/me....tvdb.com/
I tried putting them in the TVshows.nextaired folder but it wouldnt even run?
2019-11-24, 19:43
(2019-11-24, 19:40)startreksteve Wrote: [ -> ]And where should these files go?Instructions can be found here on how to install an add-on: How to install from a ZIP file.
Shedrock
2019-11-24, 19:45
(2019-11-24, 19:43)shedrock Wrote: [ -> ]Ah! So I install it as though Im installing an addon?(2019-11-24, 19:40)startreksteve Wrote: [ -> ]And where should these files go?Instructions can be found here on how to install an add-on: How to install from a ZIP file.
Shedrock
2019-11-24, 19:50
Shedrock
That's correct. Remember, you are only installing the latest update. Not all 3.
Shedrock
Shedrock
2019-11-24, 19:55
(2019-11-24, 19:50)shedrock Wrote: [ -> ]Shedrock
[/quote]
Shedrock
[/quote]
Yeah did that, still doesnt work, does a scan then crashes at the end. Should I remove the .zip line in the modded script?
2019-11-24, 20:15
(2019-11-24, 19:55)startreksteve Wrote: [ -> ](2019-11-24, 19:50)shedrock Wrote: [ -> ]Shedrock
Shedrock
[/quote]
[/quote]
Im running on a Pi2 on Libreelec Leia, with or without the modded script Im not getting an data coming down.
2019-11-24, 20:21
(2019-11-24, 20:15)startreksteve Wrote: [ -> ](2019-11-24, 19:55)startreksteve Wrote: [ -> ](2019-11-24, 19:50)shedrock Wrote: [ -> ]Shedrock
Shedrock
[/quote]
[/quote]
If we're running the modifies script with the .zip part in it, shouldnt we also change the entry in this part?
in updates_%s.xml
def _get_update_info(self, period, filter_func = None, callback = None):
url = "%s/updates/updates_%s.zip" % (self.base_zip_url, period)
zip_name = 'updates_%s.xml' % period
2019-11-24, 20:39
Might just be best to disable the addon until tvdb.com get all their fixes done.
2019-11-25, 14:18
will the addon itself be upated cos iv tried the fixed with no joy
2019-11-25, 19:05
(2019-11-25, 14:18)turbotec Wrote: [ -> ]will the addon itself be upated cos iv tried the fixed with no joy
The filename problem (addition of "zip") is already ticketed for the tvdb api team, which means it should be fixed / restored to the former way.
Which would make an update of the NextAired Add-on unnecessary, at least premature, for the moment.
2019-11-26, 00:00
Hi
Ive got the most current metadata.tvDB.zip updated now, but the TV guide for "NextAired" still errors at 15% when trying to grab a guide update. Is there something Im missing? Or is this just the TVDB ppl still doing their updates?
