2020-03-25, 23:00
(2020-03-25, 09:52)Marklar Wrote: [ -> ]It's 6.0.15, will latest version be pushed out from repo?Just waiting for a response in the PR.
https://github.com/XBMC-Addons/script.tv...-363005121
(2020-03-27, 04:35)Marklar Wrote: [ -> ]6.0.17 crashes when it reaches "Star Trek" This is the error log
2020-03-27 09:03:59.850 T:25764 NOTICE: script.tv.show.next.aired: ### getting series & episode info for #77526 - Star Trek
2020-03-27 09:03:59.944 T:25764 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: (22, 'Invalid argument')
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.tv.show.next.aired\service.py", line 6, in <module>
NextAired()
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.tv.show.next.aired\default.py", line 178, in __init__
self.do_background_updating()
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.tv.show.next.aired\default.py", line 298, in do_background_updating
if self.update_data(update_every):
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.tv.show.next.aired\default.py", line 588, in update_data
tid = self.check_show_info(tvdb, tid, current_show, prior_data)
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.tv.show.next.aired\default.py", line 992, in check_show_info
dt = dt.astimezone(tz.tzlocal())
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.module.dateutil\lib\dateutil\tz\_common.py", line 144, in fromutc
return f(self, dt)
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.module.dateutil\lib\dateutil\tz\_common.py", line 258, in fromutc
dt_wall = self._fromutc(dt)
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.module.dateutil\lib\dateutil\tz\_common.py", line 222, in _fromutc
dtoff = dt.utcoffset()
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.module.dateutil\lib\dateutil\tz\tz.py", line 222, in utcoffset
if self._isdst(dt):
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.module.dateutil\lib\dateutil\tz\tz.py", line 291, in _isdst
dstval = self._naive_is_dst(dt)
File "C:\Users\user111\AppData\Roaming\Kodi\addons\script.module.dateutil\lib\dateutil\tz\tz.py", line 260, in _naive_is_dst
return time.localtime(timestamp + time.timezone).tm_isdst
ValueError: (22, 'Invalid argument')
(2020-03-27, 15:23)Danp Wrote: [ -> ]6.0.15 doesn't crash but I get no results in the guide at all(2020-03-27, 04:35)Marklar Wrote: [ -> ]6.0.17 crashes when it reaches "Star Trek" This is the error log
NextAired()
return f(self, dt)
if self._isdst(dt):
apparently it does not recognise pre 1970's, thats why i stuck with 6.0.15 it scans but does not update
(2020-03-27, 15:25)Marklar Wrote: [ -> ](2020-03-27, 15:23)Danp Wrote: [ -> ]6.0.15 doesn't crash but I get no results in the guide at all(2020-03-27, 04:35)Marklar Wrote: [ -> ]6.0.17 crashes when it reaches "Star Trek" This is the error log
NextAired()
return f(self, dt)
if self._isdst(dt):
(2020-03-27, 15:23)Danp Wrote: [ -> ]Suddenly I get this error too, concerning a show very much post 1970... A few days ago it was all still working, I am absolutely clueless(2020-03-27, 04:35)Marklar Wrote: [ -> ]6.0.17 crashes when it reaches "Star Trek" This is the error log
NextAired()
return f(self, dt)
if self._isdst(dt):
(2020-03-27, 15:47)Danp Wrote: [ -> ]Country.db from 6.0.15 when it did work properlySeems to have worked. Getting update failed but I can see results of upcoming shows in guide.
(2020-04-08, 20:03)Danp Wrote: [ -> ]Not that i know of. TVDB shows original air dates anyway
