Full Version: TV Show Next Aired (Script) Addon, now w/TheTVDB data
(2024-05-21, 23:27)Fuchs2468 Wrote: [ -> ]I have good news for you "TV Show - Next Aired" also works with Kodi Omega!
Since a change has been made to the standard date format in Kodi Omega, a small change in the Kodi settings is required.
The addon should then work again.
What needs to be changed in the Kodi settings:
- go to kodi => settings => interface
- activate setting level "expert"
- go to "Long date format" and change the default format
- I use the format "(DDDD,DD MMMM YYYY)"
If you change the language, you will need to restart Kodi!
But now the addon should work again.
Not all formats in the "Long date format" list work, but test and write which formats work for you.
@rafikW
@piramiday
Have the two of you seen this? !
@Fuchs2468
You sir are a genius!
Thank you very much.
I tried it, it works!!
I don't have time this week to check it out, but I'll definitely test it this weekend, but it looks promising, so that would be really GREAT NEWS.
[EDIT] Yes, I can confirm it works in Kodi 21. (DDD, DD MMMM YYYY) instead of (DDDD, D MMMM YYYY) did the trick!
@Fuchs2468 - VERY BIG THANKS for finding this solution. I don't know if you did that by analyzing python code or by accident, but you are indeed a genius like @melons2 wrote :-)
Thanks for the update
Thanks for the hard work
Where can I download the add-on from ? Thank you
(2024-06-18, 11:08)MeGuinness Wrote: [ -> ]Where can I download the add-on from ? Thank you
The addon is included in my repo.
Look here:
repository.fuchs246-1.0.2.zip
(2024-06-18, 11:57)Fuchs2468 Wrote: [ -> ]
Look here:
Thank you,will this work with the stock default skin?
Look here:
(2024-06-18, 12:26)MeGuinness Wrote: [ -> ]Thank you,will this work with the stock default skin?
Yes, with every skin.
