Full Version: Help with advancedsettings.xml Cleanstrings
I am using the Netflixbmc addon. It has an export feature that allows you to export favorites to .strm files then scan to the library. The TV Series are exporting in the format "Series Name (2001-2003)". The scraper is having trouble getting rid of the dates. It works just fine for shows that only have one season (Series Name (2001)). Can someone help me with the correct cleanstrings regexp to add to advancedsettings.xml?
