Full Version: how to refresh add on and repository on rasberry pi
I have watched a lot of tutorials about addons and repositories. I am wondering how I can update / refresh repository or addons on raspberry pi, (openelec) with Iphone app called xbmc remote? I know how to do it but I don't know what key should I use to get pop up window with refres option etc?
I have tried all possibilites to get window with:
- refresh repo
- force reload repo
- uninstall install repo
but no success.
Thank you in advance,
koze
I would like to come back to my question.
Once again I am using RPi with XBMC 12.2 installed. As a remote control I am using XBMC app installed on my Iphone. I would like someone to let me know how I can get below pop up window to show up on my screen.
http://wiki.xbmc.org/images/thumb/0/06/R...efresh.png
Thank you for your help.
koze
I missed your first post!
You need to activate the "context menu". From within the remote control view you can activate it with:
Button Pad: Long press the button in the bottom right of the directional buttons (see the help screen)
Gesture Zone: Tap and hold shows the context menu dialog (see the help text inside the touch area)
Thanks. That is what I need it.
Thank you,
koze
