Hey all I was just wondering is it possible to make it so when your on the home screen and you have library mode enabled when you press either movies or tv shows for it to take you directly to title instead of having to press down then across to title
Many thanks
Paul
By default it does do that. The 'title' submenu doesnt really need to be there...
Mmmm when ever I press it, it takes me to a list that shows movies, tv shows, addons and so on
Any ideas
Many thanks
Paul
Which skin? Which version of XBMC?
Are you by any chance using the directory navigation (..) instead of pressing escape on your keyboard / the menu button on your remote ?
XBMC will remember your position so if you purposefully step back to the title menu and then back to the main menu it will remember.
