2014-02-15, 23:26
I make use of Cachemembuffersize and buffermode=1 and readbufferfactor=4.0 . It works well because I can pause and cache fills up making smoother playback.
In Gotham alpha 8 I was able to use 1.5GB cache in RAM fine, I verified by viewing the OSD debug screen that it would fill this cache.
However in these latest nightlies even though I set to 1.5GB ram. It is only using about 750MB.
So what has changed here? My system has 16GB RAM. When under full stress the system uses 4GB of RAM and has 11-12 GB available. I understand xbmc will use 3 times the amount I set but it doesn't even get close to that.
My system has no paging file. And I am not interested to setting the buffercache to 0 because I only have an ssd in the system and don't want xbmc thrashing it.
Any help or trick I could try would be appreciated. Thanks!
