2014-02-16, 15:22
Hi all,
I'm hoping I can get some help with a fault I'm getting with my HTPC.
The specs are:
MB - Asus E35m1-i Deluxe (Integrated AMD Dual-Core Processor E-350 with AMD Radeon™ HD 6310 Graphics)
Power - Pico 120W
RAM - 4Gb DDR3
HDD - 64Gb Crucial RealSSD M4
OS - Windows 7 Home Premium 64
It has been running for about 3 years with no issues but a few months back I got a BSOD and continued to do so. I reinstalled Windows and the fault continued. Basically I get a BSOD after a period of 20mins+ with the computer sitting at idle (no programs running). I took the PC to a local repair specialist and they said that they suspected that the MB was at fault so I'm assuming that they tested the RAM, HDD etc. etc.
I tried booting up a linux live USB (various distros) and left the computer running and sure enough the computer remained on overnight, however the SSD was no longer detected either by Linux or in the BIOS. I do not know if this is related? I tried swapping the SATA ports with the BD-ROM drive and it was detected again. I later tried to install Linux (50:50 partition) alongside Windows 7 but I got as far as entering my name, computer name etc. and I got an error and could not continue with the installation. When I booted into the BIOS, again the SSD was not there but the BD-ROM drive was. I updated the firmware on the SSD and also updated the BIOS to the latest version but to no avail.
The only things I have not tried yet are swapping the RAM (a friend is going to lend me a spare stick to try) and trying another SATA cable and hard drive.
I have just booted up Elementary OS using a liveusb stick and during the boot up sequence I noticed "ata2" issues resulting in reduced speed (3Gbs). When the boot sequence finished the drive was not connected, yet the BD-ROM drive was.
Could the problem be the SATA cable or SSD as the BD-ROM drive is always detected? I only experience the SSD drive not connected issue when I use Linux. I've always been able to boot into Windows okay but obviously get the BSOD after a period of time. Are there any checks that I can do on the MB? I'm afraid my knowledge is very limited to basic plugging/unplugging components!
If the MB is indeed the culprit, what would a suitable replacement be? I assume that repairing it would not be financially viable. I did notice sound issues when using Linux so I'm assuming that another AMD GPU setup is out. As I was only ever using live versions of Linux, I assume that the drivers would only work in the installed version? (My knowledge of Linux is zero)
Any help or pointers you could give me to hopefully resolve this without further financial outlay would be very much appreciated!!
The specs are:
Power - Pico 120W
RAM - 4Gb DDR3
