Full Version: mc2xml cron job not working
I have the tvheadend back end running. I can run mc2xml from the directory it resides in (/home/hts/mc2xml/) but if i try and run it from the full path in order to have a script in the cron.daily directory to run it, it errors out with a:
Loading ..... : mc2xml (c) <[email protected]> (v1.2)
Reminder .... : Unauthorized redistribution prohibited.
Reminder .... : If this software is useful, please donate!
Missing -g
any ideas? all the permissions look fine and open to everyone.
Hello!
I have the same issue! Any help on that would be fine.
I was not able to find a solution so far.
/krijeck
no ideas?
any help or idea would be appreciated ....
/krijeck
(2014-02-26, 02:24)DaveNinja Wrote: [ -> ]this might be the solution:
http://forum.xbmc.org/showthread.php?tid...pid1636810
thanks for the hint. Will give this a try ... how can I find out if a cron job works?
(2014-03-02, 18:18)krijeck Wrote: [ -> ]
logger
I added a line in my mc2xml script that writes the date to a file in my home directory when the script it run, something like:
date > /home/username/last_time_mc2xml_ran.txt
My tvheadend program guide has been staying up to date so the fix was good
