(2014-02-22, 14:46)uNiversal Wrote: [ -> ]VFD, its now a addon
Thanks for that..., this indeed fixes my VFD problem.
I thought I'll attach some mediainfo for my problem videos. First two have issues, the first one is unwatchable, the second is in fact the very video that the debug was created on, the third does not have problem despite being extremely high bit rate at times:
#Video1
General
Complete name : I:\BDMV\STREAM\00800.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 39.9 GiB
Duration : 2h 14mn
Overall bit rate mode : Variable
Overall bit rate : 42.6 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 2h 14mn
Bit rate mode : Variable
Maximum bit rate : 35.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
#Video2
Format : BDAV
File size : 3.11 GiB
Duration : 15mn 38s
Overall bit rate : 28.5 Mbps
Video #1
Menu ID : 1 (0x1)
Format : AVC
Format profile :
[email protected]
Codec ID : 27
Duration : 15mn 37s
Maximum bit rate : 36.5 Mbps
Color space : YUV
Bit depth : 8 bits
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
#Video3
General
Complete name : L:\BDMV\STREAM\00001.m2ts
Format : BDAV
File size : 27.1 GiB
Duration : 1h 54mn
Overall bit rate : 33.8 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile :
[email protected]
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 1h 54mn
Color space : YUV
Bit depth : 8 bits
RGDS Joe
