Full Version: Problem with skin?
I'm having a strange thing.
Running openelec xbmc 12.2 for some time now.
Installed mq5 a long time ago, never had problems
Last week , i turned on my machine again, and plop the default confluence skin was on.
I didnt know what happened cause i didnt change a thing
when i looked, i saw that mq5 was installed but couldnt select it
I redownloaded, and chose the skin
Restarted the machine, and hup, again confluence skin is showing (although settings says mq5 is installed, but i cant chose it in "skins" appearance)
Very strange
Skin problem?
Why did it work for months, and now suddenly it does not?
It sounds like it is due to the most recent skin update. I'm not sure what to suggest other than uninstalling and reinstalling the skin. But it sounds like you've already done that.
yeah Sad
Don't know whats wrong
