Full Version: Channels Will Not Play
Odd error as I have had this working for a few weeks, now every time i try to play a channel nothing happens. I press enter and no channel will play. Can someone help? here is my log:
2014/02/17 09:42:05.369 OpenLiveStream> -----------------start------------------------
2014/02/17 09:42:05.369 OpenLiveStream> client: sean requesting live stream
2014/02/17 09:42:05.369 StreamProc> live-tv started
2014/02/17 09:42:05.371 SetChannel> Tuner: HDHomeRun Prime Tuner 13179509-1 / dfcc8381-c580-4b12-b318-0722c84f3980
2014/02/17 09:42:05.371 SetChannel> > Digital: True
2014/02/17 09:42:05.371 SetChannel> > Encrypted: False
2014/02/17 09:42:05.371 StreamProc> process start error: System.Runtime.InteropServices.COMException (0x80070490): Element not found. (Exception from HRESULT: 0x80070490)
at ehiProxy.RecorderMgrClass.FindRecorderByID(Guid guid, IRecorderInfo& ppRecorder)
at ServerWMC.Worker.RecordToWTV.SetChannel(Channel newC)
at ServerWMC.Worker.RecordToWTV.ChangeChannel(Channel c, String newFileName)
at ServerWMC.Worker.RecordToWTV.StartNewRecording(Channel c, String fileName, String clientName)
at ServerWMC.Worker.StreamProc..ctor(String clientName, Channel c)
2014/02/17 09:42:05.371 StreamProc> calling Close()
2014/02/17 09:42:05.371 StreamProc::Close> remuxer was not running
2014/02/17 09:42:05.371 StreamProc::Close> wtv was not running
2014/02/17 09:42:05.371 StreamProc::Close> closed in 0.00 sec
2014/02/17 09:42:05.371 OpenLiveStream> error: System.Runtime.InteropServices.COMException (0x80070490): Element not found. (Exception from HRESULT: 0x80070490)
at ServerWMC.Worker.StreamProc.StartStream(String clientName, Channel c, Boolean& alreadyStreaming)
at ServerWMC.Worker.RecService.OpenLiveStream(String[] args)
2014/02/17 09:42:05.371 Finished request OpenLiveStream in 0.00s
Assuming nothing has changed on your server machine, it seems to be showing that the low level hardware calls we use to capture tuner output has become unavailable (or stuck in a bad state). Assuming you have already tried rebooting your swmc machine, try tuning wmc to a channel, if successful then try xbmc again.
