Full Version: [SOLVED] [RASPBIAN]-[MAC] connected to boblightd - nothing happens
Hello All,
Following my setup:
Mac Mini 2010, OS 10.7.5 - xbmc 12.3
Arduino Uno with 50 WS2801 LEDs
raspberry (raspbian) -> for daemon ONLY
boblightd is running on raspberry and xbmc connects to boblightd succesfull.
Here is my boblight.conf: http://pastebin.com/L0yJ7wcC
I made the boblightd by following a german guide:
Quote:sudo apt-get update
sudo apt-get install make gcc g++ subversion
Quote:svn checkout http://boblight.googlecode.com/svn/trunk/ /home/pi/boblight_source
Quote:cd /home/pi/boblight_source/
./configure --without-portaudio --without-x11 --without-libusb
Quote:make; sudo make install
Quote:cd ~
wget https://github.com/brooc/boblight-rpi/ra...t-dispmanx
chmod 755 boblight-dispmanx
Quote:sudo nano /etc/rc.local
Quote:/usr/local/bin/boblightd -f &
/home/pi/boblight-dispmanx -b on -o interpolation=1 -o speed=90 -o threshold=35 -o autospeed=0 -o saturation=1 -o value=1 -p 100 -i 0.1 -f /dev/null &
Unfortunately nothing happens with the LEDs on xbmc.
And I really have no idea why.
I checked if the serial port and IP is correct and both definitely is.
If I do the boblight-constant command, raspberry tells me that "Connection to boblightd opened"
Does anyone have an idea what I did wrong?
Thank you
EDIT: Just want to add some more Information.
If I run the standalone adalight/processing tool, the lights work properly.
I used the guide above because it made sense to me.
If anyone has another guide, which describes how to setup a boblight daemon, I would be happy to try that!
...I'm not sure, if the dispmanx option make sense, because I read this in combination with raspbmc only.
boblight-dispmanx <- this is a client - you don't even need that when you want to use the addon (also it could interfer with it - so don't use it).
just start the boblightd (/usr/local/bin/boblightd -f &) and then start XBMC. Does this work then?
Hi Memphiz,
just tried with boblightd only.
I removed the dispmanx from start-up as first step and tried again
As second step I deleted boblight-dispmanx and tried again.
Both unsuccessful, I'm afraid. LEDs stay dark
Hi again,
I set the debug "on" just to look what happens:
http://pastebin.com/289V7bKd
Corresponding boblight.conf:
http://pastebin.com/CWzQUva9
Because I usually have an USB switch between the arduino and the Mac, I tried also the direct attach...
I checked if the tty.usbmodem Port is correct before I started boblight-constant.
Hope this helps
Hi All,
I did some testing with an iMac and 10.9, because Maverick seems not to have all that problems during startup etc., but got the same result:
ERROR: ambilight: /dev/tty.usbmodemxxx: open() No such file or directory
I'll re-install raspbian an setup the Daemon again WITH libusb and boblight-x11.
Hope that this will help Big Grin
Well it is obvious ... /dev/tty.usbmodemxxx is not there - seeems the device is called different (keep in mind it is case sensitive!)
Thanks Memphiz
I hoped that libusb includes some kind of USB drivers that may help at the connection.
But what else can I do as to ask the terminal: ls /dev/tty.* ?
I type-in what the terminal tells me. And there are no other USB devices...
So Terminal may not tell me the correct name of the serial port?
I checked the available serial ports in the Arduino Sofrware as well and this is always equivalent to Terminal.
I would appreciate, if you or someone else could give me some hint.
edit:
Memphiz, I'm aware that you are a very busy man and I don't want you to spend much resource to my non-XBMC problem...
I'll, of course, ask google as well... Just want to let you know that.
Thank you for your support!
Plug in the arduino and then hit "dmesg" ... have a look at the last lines there it might show you where the devices is located in the /dev/ directory. At the worst you are missing a kernel driver for that arduino serial2usb converter. In that case you could just post the last lines of "dmesg" after plugging the arduino in...
Yes i am busy of course - but your problem only needs me to type some words - nothing i need to test or code for you (which would be the real time burner) - so i'm ok with that....
what I get is:
Quote:AppleUSBCDCACMData: Version number - 4.1.22, Input buffers 8, Output buffers 16
AppleUSBCDC: Version number - 4.1.22
after plugging in.
first tried "sudo dmesg"
then "sudo dmesg | grep -i usb"
Both brought the same
I thought we are talking about raspbian ... try the same on raspbian ...
Ähm..
Sorry, but the daemon runs on raspbian. The arduino is plugged to the mac. I run the daemon over network to serve the Mac. So you ment that I have to hook-up the arduino to the raspberry to find out the port? That doesn't made sense to me...? However - I'll try that...
Tanks again
Ha you are confusing me.
The daemon (boblightd) has to run on the same device where the arduino is connected to. So imo - connect the arduino to the raspbian - get the /dev/tty.blahbah device - adapt the boblightd.conf on the raspbian with that device. Then connect your clients via network to the raspbian.
That's how it is ment to be done if you ask me.
Honestly
I Love You Memphiz!
Don't know how I could thought this Arduino has to be plugged to the Mac.
I'm sure sou think I'm stupid - Lololol
You gave me the hint! So I really Love You!
You have no idea how many hours I tried to get it work.
Kaum macht mans richtig, schon gehts!
Many many thanks
