I have removed pulseaudio and I now have sound in Gotham....but I'm still experiencing the audio drops/silences. During the last playback it occurred about 3 times in a few minutes. Here's the new
log
Quote:19:04:13 T:2755656512 DEBUG: OutputPicture - change configuration. 1278x720. framerate: 23.98. format: VAAPI
19:04:13 T:2755656512 NOTICE: Display resolution DESKTOP : 1920x1080@ 60.00 - Full Screen (16)
Playing 23.98 fps @ 60 hz sucks. What's your sync method? Sync Playback to Display is activated, if yes - it makes no sense to sync 23.98 to a 60hz refreshrate? What upscaler are you using?
Sync playback to display is off. I did try all the available sync methods, but the glitch keeps reoccurring.
I don't know what you mean by upscaler. I use default XBMC settings, my PC is connected to my TV via HDMI. Sound goes to receiver via SPDIF. (If I play sound via HDMI....I have the same issue)
I used the following
site to update the alsa drivers.
I haven't noticed an audio drop since!
Thanks for the support
