Full Version: A newbie with a question.
Hi Everyone, I'm a newbie so go easy on me if I appear to be a dummy! I have just downloaded XBMC for OSX from http://xbmc.org/download/ however when I try to open it I get the message "XBMC can't be opened because it is from an unidentified developer" I have a Macbook Air running 10.9.1 Mavericks. Has anyone come across this before? More importantly does anyone know of a work round?
Thanks for any help.
system preferences -> security & privacy -> Allow applications downloaded from: -> everywhere
Ah, many thanks for the quick reply!!
You can also hold the option key down while you try to open it if you do not want to change the security settings.
