2014-02-21, 06:05
This skin is now HELIX only
Requirements / Supported Addons
Skin Widgets
library.service.data.provider
script.favourites
Global Search
Tv Tunes
Artist Slideshow
CU LRC Lyrics
Fonts with Hebrew Support
http://forum.kodi.tv/showthread.php?tid=...pid1878053
What wont be supported
Extrafanart / Extrathumbs
Credits
Iconmonstr.com for ui icons
Piers for video add-on icons -- http://metroicon.net/
Meterocons for weather icon font
redhalo for pseudotv skin
Frequently Asked Questions (FAQ)
Q. How can I customize the home menu?
A. Easy, just go to Settings > Skin Settings > Home Screen > Customise
Q. How can I make a new tile between two other tiles?
A. Customize > Click where you want to insert the tile and choose "insert tile"
Q. How can I set a tile for all my favourites?
A. Customize > Click the tile you want to set and choose "edit path". Set the path to:
Don't forget to give the tile an icon and label also.
Q. How can I skip the hubs and go straight to my library?
A. Customize > Click the tile you want to change and choose "edit path". Set the path to:
For Movies:
For TV:
For Albums:
For Artists:
For PVR:
Q. What are some of the other paths I can use?
A. Library paths: http://wiki.xbmc.org/?title=Opening_Windows_and_Dialogs
Other http://wiki.xbmc.org/?title=Window_IDs
Q. What other functions can I use in edit path?
http://wiki.xbmc.org/index.php?title=Lis..._functions
For example, you can have a reboot tile with the path:
Or you can have an update library tile with the path:
Q. How can I set a path to a folder of video or music files?
For Videos:
For Music:
Change /path/to/your/files/ to the path you want to use.
Q. How can I set individual colours for tiles?
A. In Settings > Skin Settings > Home Screen, you need to disable "use theme colours for focused tiles". Then you can set colours for tiles in the home customization screen by clicking on a tile and choosing "set colour"
Q. How can I set individual background widgets per tile?
A. In Settings > Skin Settings, click "Set global background widget" and choose "disable". Now you can set background widgets for individual tiles in the home customization screen.
Q. Why does my custom smart playlist widget take so long to load?
A. You need to limit the number of items it displays to 10 in the smart playlist editor.
Q. Why doesn't my computer shutdown when I choose shutdown from the power menu?
A. In Settings > System > Power Saving, you need to change the shutdown function from Quit to Shutdown.
watch gallery
Skin Widgets
script.favourites
Global Search
Tv Tunes
Artist Slideshow
CU LRC Lyrics
Credits
ActivateWindow(favourites)
For Movies:
ActivateWindow(videos,videodb://movies/titles/,return)
ActivateWindow(videos,videodb://tvshows/titles/,return)
ActivateWindow(music,musicdb://albums/,return)
ActivateWindow(music,musicdb://artists/,return)
ActivateWindow(MyPVR)
Reboot
UpdateLibrary(video)
For Videos:
ActivateWindow(videos,/path/to/your/files/,return)
ActivateWindow(music,/path/to/your/files/,return)
