I'm trying to build XBMC for Android x86. I'm using Ubuntu 12.04 64bits.
I have installed ndkr9 and latest sdk.
Have installed these libs:
sudo apt-get install build-essential default-jdk git curl autoconf unzip zip zlib1g-dev gawk gperf cmake
sudo apt-get install ia32-libs
Executed this command:
./make-standalone-toolchain.sh --ndk-dir=../../ --install-dir=${TOOL_CHAIN}android-14 --platform=android-14 --toolchain=x86-4.8 --arch=x86 --system=linux-x86_64
then boostrap in tools depends and configure:
sudo ./configure --with-tarballs=/opt/xbmc-tarballs --host=i686-linux-android --with-sdk-path=/home/phi_admin/android-sdk-linux --with-ndk=/home/phi_admin/android-ndk-r9/ --with-toolchain=/home/phi_admin/android-ndk-r9/platforms/android-14 --prefix=/opt/xbmc-depends
Here is the configure logs:
http://pastebin.com/yQphAzyq
then i'm calling make.
However make of dependency is failing. Here is the log for the make -j 20:
mpih-add1-asm.S: Assembler messages:
mpih-add1-asm.S:47: Error: invalid instruction suffix for `push'
mpih-add1-asm.S:48: Error: invalid instruction suffix for `push'
mpih-add1-asm.S:78: Error: operand type mismatch for `jmp'
mpih-add1-asm.S:113: Error: invalid instruction suffix for `pop'
mpih-add1-asm.S:114: Error: invalid instruction suffix for `pop'
make[5]: *** [mpih-add1-asm.lo] Error 1
make[4]: *** [all-recursive] Error 1
make[3]: *** [all] Error 2
make[2]: *** [i686-linux-android-android-14/src/.libs/libgcrypt.a] Error 2
make[1]: *** [libgcrypt] Error 2
make: *** [target/.installed-i686-linux-android-android-14] Error 2
The full logs are here:
http://pastebin.com/Bvz2eH2B
Any ideas what is wrong?
please use pastebin.com and remove the pasted stuff
Your toolchain isn't used ... post tools/depends/config.log ... also what is ${TOOL_CHAIN}
Think this is wrong:
it should point in here
/home/phi_admin/android-ndk-r9/toolchains/x86-4.8/prebuilt/linux-x86_64/
isn't it?
Apparently it was the toolchain.. it's building...
Being a thick Welshman and all that I don't understand why you're trying to build XBMC for Android x86 when xbmc already has an Android x86 Gotham build out or am I missing something??
I repeat my question - what is ${TOOL_CHAIN} in your cmdline you posted. The Toolchain dir has to match what you have given as install-dir in the make-standalone-toolchain.sh command ...
Hi sheepybach,
unfortunately our customer wants to use the DVD player of his Android device, and XBMC has DVD player libraries in it. However they are not being used in the Android XBMC app version, I want to make them available.
In order to do so I need to re build it.
Hi memphiz,
I found out that I was using the toolchain r9 which is wrong. I'm re trying with the r8 now.
r9 was fine ... r9e (or any other letter) is not.
Hi, i'm trying to build XBMC for Android x86 on the same computer of Coutinho (we work together), I advanced few steps, but it generated an error.
I executed this command: OK
sudo ./make-standalone-toolchain.sh --ndk-dir=../../
--install-dir=/home/phi_admin/android-ndk-r9/toolchains/x86-4.8/prebuilt/linux-x86_64/
After this command: but output was : "key already exists", then i believe that is correct.
sudo keytool -genkey -keystore ~/.android/debug.keystore -v -alias
androiddebugkey -dname "CN=Android Debug,O=Android,C=US" -keypass
android -storepass android -keyalg RSA -keysize 2048 -validity 10000
after in /xbmc-android/tools/depends, executed these three commands
1 - phi_admin@Phi02:~/xbmc1/xbmc-android/tools/depends$ sudo ./bootstrap
2 - phi_admin@Phi02:~/xbmc1/xbmc-android/tools/depends$ sudo ./configure
--with-toolchain=/home/phi_admin/android-ndk-r9/toolchains/x86-4.8/prebuilt/linux-x86_64
3 - phi_admin@Phi02:~/xbmc1/xbmc-android/tools/depends$ sudo make -j1
in "sudo make -j1", this command run for ~10 minutes, then:
/home/phi_admin/android-ndk-r9/toolchains/x86-4.8/prebuilt/linux-x86_64/bin/../lib/gcc/i686-linux-android/4.8/../../../../i686-linux-android/bin/ld:
error: /opt/xbmc-depends/i686-linux-android-android-14/lib/libusb.a(usb.o):
incompatible target
error: /opt/xbmc-depends/i686-linux-android-android-14/lib/libusb.a(linux.o):
incompatible target
../.libs/libusbpp.a(usbpp.o):usbpp.cpp:function
USB:evice:tring(std:tring&, int, unsigned short): error:
undefined reference to 'usb_get_string'
USB:evice::controlTransfer(unsigned char, unsigned char, unsigned
short, unsigned short, unsigned short, unsigned char*, int): error:
undefined reference to 'usb_control_msg'
USB::Interface::driverName(std:tring&): error: undefined reference
to 'usb_get_driver_np'
../.libs/libusbpp.a(usbpp.o):usbpp.cpp:function USB::Busses::rescan():
error: undefined reference to 'usb_find_busses'
error: undefined reference to 'usb_find_devices'
error: undefined reference to 'usb_get_busses'
error: undefined reference to 'usb_open'
../.libs/libusbpp.a(usbpp.o):usbpp.cpp:function USB::Busses::Busses():
error: undefined reference to 'usb_init'
USB:evice::~Device(): error: undefined reference to 'usb_close'
collect2: error: ld returned 1 exit status
make[5]: *** [descriptor_test] Error 1
make[5]: Leaving directory
`/home/phi_admin/xbmc1/xbmc-android/tools/depends/target/libusb/i686-linux-android-android-14/tests'
make[4]: Leaving directory
`/home/phi_admin/xbmc1/xbmc-android/tools/depends/target/libusb/i686-linux-android-android-14'
make[3]: Leaving directory
make[2]: *** [i686-linux-android-android-14/.libs/libusb.a] Error 2
make[2]: Leaving directory
`/home/phi_admin/xbmc1/xbmc-android/tools/depends/target/libusb'
make[1]: *** [libusb] Error 2
make[1]: Leaving directory
`/home/phi_admin/xbmc1/xbmc-android/tools/depends/target'
Error log ( Last piece of terminal):
http://pastebin.com/igD0AH0c
know about? any ideas?
Jenkins builds this fine each night. See the output of a complete build here:
http://jenkins.xbmc.org/job/XBMC-Android...onsoleFull
See our configure line:
./configure --with-tarballs=/home/jenkins/xbmc-tarballs --host=i686-linux-android --with-sdk-path=/home/jenkins/android-dev/android-sdk-linux --with-ndk=/home/jenkins/android-dev/android-ndk-r9 --with-toolchain=/home/jenkins/android-dev/x86-linux-4.8-vanilla/android-14 --prefix=/home/jenkins/workspace/XBMC-Android-X86@2/tools/depends/xbmc-depends
Especially the --with-toolchain which points to /home/jenkins/android-dev/x86-linux-4.8-vanilla/android-14
This should be /home/phi_admin/android-ndk-r9/toolchains/x86-4.8/prebuilt/linux-x86_64/android-14 on yours ... (check if there is an android-14 subdir) ... i guess there is still something wrong with the configure line.
In the "make-standalone-toolchain.sh" command, the "--install-dir" should point to a separate, new directory.
Having "--install-dir=/home/phi_admin/android-ndk-r9/toolchains/x86-4.8/prebuilt/linux-x86_64/" is wrong. It installs on itself and you probably corrupted your ndk.
Quote:The --install-dir option (and therefore the <android-toolchain-arm>/<android-toolchain-x86> value)
specifies where the resulting toolchain should be installed (your choice).
Thats even worse then i figured
I run these commands with yours tips:
This command i change the "install-dir" and download a new ndk, case i had corrupte my last ndk.
# sudo ./make-standalone-toolchain.sh --ndk-dir=../../ --install-dir=$HOME/toolchain/android-14 --platform=android-14 --toolchain=x86-4.8 --system=linux-x86
Now my configure run perfectly.
# sudo ./configure --with-tarballs=/opt/xbmc-tarballs --host=i686-linux-android --with-sdk-path=/home/pazeto/Android/android-sdks --with-ndk=/home/pazeto/Android/android-ndk-r9b1 --with-toolchain=/home/pazeto/toolchain/android-14 --prefix=/opt/xbmc-depends
then, i run this:
#sudo make -C tools/depends/target/xbmc
and after, this:
# make
then:
AR xbmc/commons/commons.a
CPP xbmc/android/activity/android_main.o
CPP xbmc/android/activity/AndroidFeatures.o
CPP xbmc/android/activity/AndroidKey.o
CPP xbmc/android/activity/AndroidTouch.o
CPP xbmc/android/activity/AndroidMouse.o
AndroidMouse.cpp: In member function 'bool CAndroidMouse::onMouseEvent(AInputEvent*)':
AndroidMouse.cpp:48:11: warning: unused variable 'mousePointerId' [-Wunused-variable]
int32_t mousePointerId = AMotionEvent_getPointerId(event, mousePointerIdx);
CPP xbmc/android/activity/AndroidJoyStick.o
In file included from AndroidJoyStick.cpp:22:0:
AndroidExtra.h:35:25: error: expected identifier before numeric constant
#define AKEYCODE_ESCAPE 111
AndroidExtra.h:35:25: error: expected '}' before numeric constant
AndroidExtra.h:35:25: error: expected unqualified-id before numeric constant
In file included from /home/pazeto/toolchain/android-14/sysroot/usr/include/android/input.h:45:0,
from /home/pazeto/toolchain/android-14/sysroot/usr/include/android/native_activity.h:27,
from XBMCApp.h:27,
from AndroidJoyStick.cpp:23:
/home/pazeto/toolchain/android-14/sysroot/usr/include/android/keycodes.h:259:1: error: expected declaration before '}' token
make[1]: *** [AndroidJoyStick.o] Error 1
Error log ( Last piece of terminal ):
http://pastebin.com/81tzWbGr
thanks for the replies, and you know about this error?
