Full Version: Xbmc will not run
I use gbox mx2 midnight android. Everything was working fine. I turned it off went to work and came home to use it. I turned on gbox and android system seems to work fine. I go to open the xbmc icon and now nothing just a black screen. I have no idea what happened. I have tried to unplug it...turn on and off...and checked the hdmi cable. Still nothing is this a software issue and what do i do to fix it. Help!
I think there is/was an issue with either older versions of XBMC where having a USB mouse/remote or something plugged in would cause a black screen when first starting XBMC. I believe this is fixed in nightly builds (wiki). That or it was a firmware issue, but I'm not entirely sure off hand.
