In DialogVideoInfo.xml:
PHP Code:
$INFO[ListItem.Art(season.poster)]
Returns true at episode level, and false at season level.
However
PHP Code:
$INFO[ListItem.Art(Poster)]
Also returns false at season level.
Seems to me there should be a way to display the season poster here?
I also tried
PHP Code:
ListItem.Property(SeasonThumb)
but I think that one is (or should be) deprecated anyway?
On seasonlevel its listitem.icon iirc. Note that container.content (seasons) is not available in videoinfo, so its best to use a variable and have it fallback to icon.
I'm pretty sure $INFO[ListItem.Art(season.poster)] used to work. In the wiki it specifically states it's for use in DialogVideoInfo.xml
ListItem.Icon returns the tv show poster instead of the season poster.
I am using variables here, but to be sure I tested the availability with an image control directly.
If you do "Info" while on a season you actually get the tvshow info. Thus, season.poster ofcourse doesn't exist.
ListItem.Art(Poster) should exist if the TVshow has a poster.
Ah right, its still tvshow info on season level so there's no season thumb.
Yeah I suppose that makes sense
It just that when I'm browsing through season level I'm seeing a different poster than when I press info. That feels somewhat....weird
I'm able to show the season poster at episode level, maybe I was confusing the availability with that.
I'll settle for the tv show poster then
