I have an android home theater pc with xbmc and it has worked fine up till now, once I try to open up the program it will immediately exit back to the same screen. Is there anyone with this same issue? or have any solutions? Thanks
If you have an advancedsettings.xml file you may rename it or move it and try again. When I moved from one version of gotham alpha to another the movie database changed and my MySQL settings in advancedsettings.xml were the culprit. I had to drop my old databases and then let it rebuild. There was probably a better way to do this but I didn't want to take the time to troubleshoot it. I saw the issue in the XBMC.log file.
