On Aeon MQ 5 when I start the library update as soon as I change menu (or even if I remain on the same page) the top bar disappears. The only way to see the effective status is to switch to confluence skin
(2014-02-23, 19:21)m.savazzi Wrote: [ -> ]On Aeon MQ 5 when I start the library update as soon as I change menu (or even if I remain on the same page) the top bar disappears. The only way to see the effective status is to switch to confluence skin
Same with me... CanĀ“t see the status bar anymore
I also have the same problem. Doing a full reset of the skin did not help.
What platform are you guys running?
I haven't had this occur on Openelec, Windows or Android.
I'm on OpenELEC, newest Eden with the general build.
It's probably unrelated, but have you considered upgrading to Frodo?
Ah. My bad. I'm on Frodo.
Frodo on window
is a 100% repro bug... Always happens
