(2014-03-23, 20:14)Jönke Wrote: [ -> ]I´was using http://forum.xbmc.org/showthread.php?tid=67012 a month back and my starred album/tracks was found also in album view.
Se this video starting at 0:16 http://www.youtube.com/watch?v=xFSdxKyWXpU
So some sort of album view would be nice
Any idea how to solve this error, when trying to access Starred on a Raspberry pi ? (works on my htpc)
Spotlight error - timed out
OK. I will think about adding some categories for starred tracks in the next release.
How many starred tracks do you have? Perhaps, it is some kind of timeout issue because fetching them takes too long.
The next version of Spotlight (1.1.0) has been released. Changes:
- New Inbox option, showing sent Playlists, Artists, Albums and Tracks from other users
- Playlist folders support. They are marked in bold in the Playlists menu
- Several fixes to make Spotlight work on BoxeeBox
- Spotify session is created lazily: if client add-on is accessed for the first time. This will prevent from crashing Spotimc if Spotlight was not accessed yet.
- Added StartSession, StopSession and HasActiveSession commands to control Spotify session from outside of Spotlight
here.
Enjoy!
(2014-03-23, 11:17)providers Wrote: [ -> ]Great plugin,
I have one issue, if i play the music in "full screen" then I only have sound for the first 10 sec, after that no sound
when the next song starts, then I again have sound for 10 sec and it mutes again.
If I play music directly from my HDD then everything works.
Im using latest nightly build of xbmc, does any body have same problem?
Start Spotlight
Start playing a album
Goto full screen (Where you see lyric)
Goto next song
let it play
Best regards
Providers
Yes I have the same problem!
Here is my log file:
http://xbmclogs.com/show.php?id=156493
(2014-03-23, 22:55)sjobbels Wrote: [ -> ] (2014-03-23, 11:17)providers Wrote: [ -> ]Great plugin,
Start Spotlight
Goto next song
let it play
Best regards
Providers
Here is my log file: http://xbmclogs.com/show.php?id=156493
I found a solution
Goto the lyric plugins options,
tTurn off theese two things.
Best Regards
Providers
(2014-03-18, 13:18)martinconroy Wrote: [ -> ]Getting 10061 connection errors here. What info do you need from me?
I'm still experiencing this using 1.1, and have checked I'm using my Premium details to log in. Would love to use this but currently cannot. Can I give you any information to help solve this?
Please link or paste a full xbmc log after this error occurs.
Do you know if this error occurs only on 1.1.0 or also on previous versions of Spotlight?
I checked on the latest XBMC 13 nightly build (13.0-BETA3 Git:20140324) and cannot reproduce. Could you please include or link xbmc logs.
Is it Windows or Linux or Mac?
I can't spot any exception in logs. Did you send these logs after seeing the error? Is this error happening always when you access plugin or in some particular cases?
Ok, got it! It is even happening on my older OE. I'll let you know once fix is ready.
Nice
thank you for your work! Looking forward to the new features.
the addon is great but crashes on skins that automatically load CU-Lyrics addon - MQ5 etc
disabling CU lyrics solves the problem and everything runs as expected
Don't see problem listed anywhere is this an issue with spotify API or is there a workaround?
(2014-03-27, 16:13)apbyz Wrote: [ -> ]the addon is great but crashes on skins that automatically load CU-Lyrics addon - MQ5 etc
Please look at post 48
http://forum.xbmc.org/showthread.php?tid...pid1661719
Best regards
Providers
