has anyone seen the winamp cd case plugin?
it uses a png of a jewel case over the album art, and it looks awesome!
i like to have the info bar up on the vis so i can see the album art and track info, i just thought this would look pretty!
http://www.turbodonkey.pwp.blueyonder.co.uk/case.png
respect to chokemaniac for an awsome skin!
turbo donkey
there is a thread on the pm forums (
http://chokemaniac.xbmc.org) about how to do this. you can also look at the 'orbs' skin, i think it has it implimented.
hello,
i have integrated your case.png quick&dirty into the musicoverlay.xml...
here is the result:
screenshot
looks not really perfect, because i only changed the order of music_retangle and music_thumb, i dont changend the image sizes in the xmls...
would be great if a real skinner could do this...?
cu lolol
(lolol @ mar. 12 2006,22:26 Wrote:hello,
here is the result:
screenshot
cu lolol
thats exactly what i had in mind!
i would love to see this added to a skin! (pm3)
the template is nice indeed but still i want to keep the icons simple
most likely wont add it to pm3
its not too hard to implement it yourself tho - grab "the orbs" and do some reverse engineering
as affini said, my boards will help you to pull this off, too
