Full Version: Cover case not showing
Usually my TV SHOW cases look like this:
but now they look like this:
Does any one know how I can fix this?
You should be addressing this to the appropriate skin subforum. What skin are you using?
Hi thrak76
Thanks for your reply!
I am using Transparency. I was wondering whether this was a skin issue or not, and decided that it was not, as I tried to reinstall the skin with no luck.
Maybe I'm wrong!
make sure this option is not enabled:
skin settings > general > tv shows - hide cases
Hi ronie
Thanks for your reply. That was exactly the problem! I found that out myself yesterday. Embarrassing Smile Must have been enabled by mistake...by someone else than me! Big Grin
