(2014-08-31, 01:55)kindrudekid Wrote: [ -> ] (2014-08-25, 09:30)Stephen88 Wrote: [ -> ]Hi guys, I'm thinking of buying this nuc, but I could not find information about whether it is capable of playing 1080p mkv encoded in H.265 or x265, can anyone help me?
plays just fine on VLC, and Windows, I think codec are missing for linux versions.
(2014-08-29, 13:34)YaPaY Wrote: [ -> ]I have looked but cant find the answer.
I own the N2820 Intel NUC and I want to buy a Xbox 360 black media remote. Only one thing is not clear for me. Can I turn on the NUC with this Remote or it works only when NUC already turned on?
You know the Xbox One Remote works fine too?, it works out of the box with OpenElec
can you send me some screen shots of media speed for a movie in 1080p x265?
p.s. yes I want use the nuc with Windows 8.1 but I am very undecided for buy the celeron or i3 haswell
Stephen88,
I have DN2820FYKH and 1080p mkv's (x264) works without
ANY problem even from Network, too. (I haven't got x265 file)
I have a question about the Remote realated. I have a philips remote controller and I set up as Microsoft PC and works under XBMC and Windows 8.1 very well. Now I want to assign/configure some keys like update library etc. For realise this I need to see all codes of RC when If I press any. Is there any way to see codes under Windows?
Just click the link. It' s fully described. In bbb case: ts
(2014-09-01, 14:53)Stephen88 Wrote: [ -> ] (2014-08-31, 01:55)kindrudekid Wrote: [ -> ] (2014-08-25, 09:30)Stephen88 Wrote: [ -> ]Hi guys, I'm thinking of buying this nuc, but I could not find information about whether it is capable of playing 1080p mkv encoded in H.265 or x265, can anyone help me?
I wish I could help you .... I use Ubuntu not windows... Tough if you could link me some videos I can try,
PS
Know this right now its software decoded... Once hardware decoding comes you should be good
(2014-09-02, 05:22)kindrudekid Wrote: [ -> ] (2014-09-01, 14:53)Stephen88 Wrote: [ -> ] (2014-08-31, 01:55)kindrudekid Wrote: [ -> ]plays just fine on VLC, and Windows, I think codec are missing for linux versions.
PS
you can try with any movie on kickass from z machine user
For anyone wanting to know, I just bought this Celeron version (I already have the i3 I'm using as a desktop) and put in 2GB of the cheapest 1.35v I could find and I can confirm, the Celeron version can play everything I've thrown at it including m2ts.
It will also bitstream HD Audio if you have a TrueHD/DTS HD compatible amp.
Front IR works.
I'm using OpenElec version 4.0.7 with BIOS firmware 32.
EDIT: This version of OpenElec:
http://openelec.tv/get-openelec/finish/8...ric-x86-64
I used the instructions listed here:
http://openelec.tv/forum/64-installation...345#110995
I however did not do the BIOS update as I figured 32 was pretty close to 34.
And yes, I had to insert the OpenElec install into the rear of the NUC otherwise it wouldn't run properly.
I'll quote the article/instructions above so you don't have to click through if you don't want to.
Quote:Just wanted to jump in and give some info on what worked for me to get everything working (except bluetooth) and I have 2 of these now.
Caveats: HDMI and f2 bios. Regardless of bios, I cannot get to f2 bios on my junky Hisense tv or my samsung computer monitor with a hdmi to dvi dongle. My Vizio tvs and through my pioneer receiver work fine. Sorry if you lost the monitor lottery. I assume you have a hardrive installed.
Bios update:
Grab the latest bios file from Intel's site that has the extension .bio (FY0034.BIO)
Grab your thumbdrive of choice.
for windows download: Rufus (rufus.akeo.ie/)
Insert thumbdrive to any windows computer.
Open Rufus. Select you thumbdrive and the GPT option. Uncheck using an Iso file. (we are just formatting the drive to a GPT partition table)
Now copy the .BIO file onto the root of the newly formatted thumbdrive. Eject your thumbdrive.
Slap it into a rear usb port on the NUC. (USB 3 ports *can* be problematic).
Boot the system and use the f7 option to update the bios from the thumbdrive. (If your drive doesn't show up, format again, try a different port, try a different thumbdrive).
It takes about 6 minutes to update and the system will reboot by itself.
Upon reboot, hit f2 to enter Bios. Uncheck UEFI boot, which will enable Legacy boot. I then fixed the time and upped the video memory to 512 MB.
Save and Exit.
Take your Thumbdrive back to your PC. Open RUFUS and reformat the drive using the MBR Partition for UEFI Computers. < (for reference I started here)
Download the .Tar file of the nightly generic 64bit version of openelec (snapshots.openelec.tv)
Open and extract the .tar file (7zip among others can be used)
Run the create_installstick.bat and follow the prompts. Double check your thumbdrive was renamed to OPENELEC.
Slap that thumdrive into a rear port and boot the NUC.
Choose the F10 Boot Menu option and boot from the thumdrive.
Follow the prompts to install OpenElec.
Reboot and remove the thumbdrive.
TADA!
This is what worked for me.
>max_rome: Simple answer is no anything plugged into the usb ports will be powered off when you power off the NUC. BUT if the NUC is powered off and you plug in a usb hardrive, the drive will power up and the NUC will still be off.
Hi I just got my NUC DN2820....
For what ever reason I could not get OpenELEC instaled on it. Even thought the BIOS was updated and I have followed EVERY instruction on the forum planet to get this resolved. Finally gave up and decided to have windows 8.1 based XBMC. Installed 8.1 successfully and installed the latest version of XBMC as well. Now the problem is I do not see Passthrough out put device. neither do I see DTS capable reciever or True HD capable reciever or anything. I would like to tell all I have a DENON X 1000 reciever, and another C2D based HTPC on GT440, where I see all these options available.
On NUC all I see is out put device, number of channels (which is 5.1) keep audio device alive, play gui sound and thats it all other options that I see in my other HTPC are not there. The only difference is the other HTPC is OpenELEC bases, and since I could not get openelec installed on NUC I have windows based XBMC.
I would also like to tell, that when I play a movie it does give 5.1 sound, but my receiver shows Multichannel instead of DTS or DolbyDigital on the display. Windows dound properties is configured as 5.1 and a test clearly plays audio in each speaker so windows is configured fine.
Under Audio ouytput device in XBMC I see
DIRECT SOUND: HDMI - DENON-AVR (Intel ® Display Audio)
WASAPI:HDMI - DENON-AVR (Intel ® Display Audio)
what ever I choose makes no difference ....
I have no idea where the problem is. why XBMC is not shown all those options and passthrough. PLEASE HELP
OK it was a small issue
.... I have to enable advance setting ..... which when done, showed me all the the options .....
(2014-09-11, 10:15)-DDD- Wrote: [ -> ]For True HD you have to use OpenElec, cause Windows Drivers does not support Passthrough HD Sound - https://communities.intel.com/message/247019#247019
ouyiii!!! I didnt know that ..... damm why is open elec so PIA on NUC ...... will have to dig in more to get this running on Open elec ....
Openelec is fine on NUC according to many other people, but as you haven't told us what exactly is going wrong, its hard to help you.
The current BIOS is 038.
Started with:
015
021
025
028
032
034
037
038
So far...lol
BIOS Notes:
*Other names and brands may be claimed as the property of others.
BIOS Update Release Notes
PRODUCTS: DN2820FYKH (Standard BIOS)
BIOS Version 0038 - FYBYT10H.86A.0038.2014.0717.1455
About This Release:
Date: July 17, 2014
TXE Firmware: 1.0.4.1089
Framework BIOS Reference Code: Based on 1.3.8
Integrated Graphics
Option ROM: Build 1018 PC 14.34
GOP Driver: 7.2.1006
LAN
Option ROM: v2.59 PXE 2.1 Build 083
UEFI Driver: 2.0.26
Visual BIOS: 2.2.7
UEFI revision: 2.3.1
New Fixes/Features:
Speeded up BIOS update process – if Intel® ME version has not changed, that segment is skipped during update.
BIOS Version 0037 - FYBYT10H.86A.0037.2014.0710.1336
About This Release:
Date: July 10, 2014
Integrated Graphics
LAN
UEFI Driver: 2.0.26
Visual BIOS: 2.2.7
New Fixes/Features:
Updated AMI build tool (VEB) to the latest version for OA3 and ITK issues.
Added support for Intel® Ready Mode Technology.
Updated Visual BIOS module to v2.2.7.
Fixed issue where Intel wireless adapters lose connectivity.
Updated GOP to version 7.2.1006.
Updated Visual BIOS to version 2.2.7.
Fixed issue where monitor will not display after S3 resume.
BIOS Version 0034 - FYBYT10H.86A.0034.2014.0513.1413
About This Release:
Date: May 13, 2014
Framework BIOS Reference Code: Based on 1.3.6
Integrated Graphics
Option ROM: Build 1007 PC 14.34
GOP Driver: 7.1.1005
LAN
UEFI Driver: 2.0.26
Visual BIOS: 2.2.5
New Fixes/Features:
Fixed issue where fan speed, temperature, and voltage are not reported in BIOS after modifying duty cycles.
Enhanced the protection of certain UEFI variables as described in Intel Security Advisory INTEL-SA-00038.
Fixed issue with BIOS password lengths.
Fixed Intel ME disable issue.
Updated GOP and VBIOS.
Fixed issue where SMBIOS values cannot be set with Intel® Integrator Toolkit.
Fixed issue where .BMP splash logo files do not display.
Fixed issue where TXE test fails.
Fixed issue where system will not boot if PXE Boot is the first boot device.
Fixed issue with Wake on USB from S4/S5.
Fixed issue where no error beeps or blinks occur when no memory modules are installed.
Fixed issue with USB3/2 compatibility.
BIOS Version 0032 - FYBYT10H.86A.0032.2014.0414.1437
About This Release:
Date: April 14, 2014
Integrated Graphics
LAN
UEFI Driver: 2.0.26
Visual BIOS: 2.2.5
New Fixes/Features:
Modified default values associated with OS Selection options.
o Windows 8.x - xHCI mode is enabled
o Windows 7 - xHCI mode is set to "smart auto"; Legacy Boot is enabled and greyed out; Wake on USB from S4/S5 is disabled and greyed out
Updated fan speed control.
Updated Visual BIOS to version 2.2.5.
Added OS Selection option in Intel® Integrator Toolkit.
Updated help text for OS Selection and USB Port.
Added Wake on USB from S4/S5 support.
Fixed issue where system wakes up if USB hot-plugging in S5 state.
Fixed fan speed issue when resuming from S3.
Fixed issue where Intel 530 series SSD is not recognized.
Fixed issue where BIOS auto-update feature fails behind a network proxy.
Fixed issue where system cannot Boot to LAN.
Fixed issue with disabling USB ports.
Fixed [WHCK] SMBIOS HCT Test issue.
Updated processor support.
Changed Cx state item string to [Lowest CPU Idle Power Setting for C6].
Updated VBIOS and GOP.
Disabled HDMI Codec Port “C”, to pass WHCK-Audio test.
Fixed issue where HDD size is incorrect in BIOS Setup.
BIOS Version 0028 - FYBYT10H.86A.0028.2014.0306.1727
About This Release:
Date: March 6, 2014
Framework BIOS Reference Code: Based on 1.3.4
Integrated Graphics
LAN
UEFI Driver: 2.0.26
Visual BIOS: 2.2.4
New Fixes/Features:
Improved fan speed control support.
Added mouse support under [F10] Boot Menu
Intel® Integrator Toolkit (ITK) fixes:
o Cannot update Setup items with ITK.
o Removed duplicate instance of “Unattended BIOS Configuration”
o Added specific project name
Fixed USB2 port compatibility issue
Fixed issue where USB keyboard/mouse fails after USB3 driver is installed under Legacy operating system.
Fixed issue where USB mouse does not work in the Boot menu.
Updated Visual BIOS to version 2.2.4, with Visual Boot Manager version 0.60.
Improved EFI variable protection for Setup variable.
Fixed compliance test issue with Intel® Smart Connect Technology.
Fixed issue where system hangs at POST code 02.
Updated PXE OPROM to v2.59.
Updated Realtek* UNDI Driver to 2.026.
Updated TXE firmware to version 1.0.4.1089 HF4.
Updated processor microcode.
Added support for the F1 hotkey to display Advanced Help Text.
Moved the OS Selection option to the top of the Boot Configuration page.
Updated message when no bootable device is found.
Fixed issue where system hangs at POST code 69 if Primary and Secondary Temperature input is PCH and Memory.
BIOS Version 0025 - FYBYT10H.86A.0025.2014.0207.1453
About This Release:
Date: February 7, 2014
TXE Firmware: 1.0.2.1060
Framework BIOS Reference Code: Based on 1.3.2
Integrated Graphics
LAN
Option ROM: v2.57 PXE 2.1 Build 083
UEFI Driver: 2.0.23
Visual BIOS: 2.2.2
New Fixes/Features:
Fixed issue that prevented installing some operating systems, such as SteamOS*.
Updated VBIOS to version 1007_20140128 to fix loss of HDMI audio.
Fixed issue where Windows 7* x64 EFI operating system installation fails.
Removed [USB3.0 (XHCI mode) support] option from BIOS Setup and enabled it by default.
Fixed issue where USB legacy SMI support is not available.
Fixed issue where Hard Disk Drive Password length did not match the specification.
Fixed issue where USB 3.0 ports do not work.
Fixed issue where items are greyed out in the Boot menu.
Fixed issue where system auto-wakes.
Added Event Log for CPU Thermal Trip.
Fixed issue where Graphics item does not show up in Intel® Integrator Toolkit.
Changed maximum number of USB mass devices from 6 to 16.
BIOS Version 0021 - FYBYT10H.86A.0021.2014.0116.1801
About This Release:
Date: January 16, 2014
Integrated Graphics
LAN
UEFI Driver: 2.0.23
Visual BIOS: 2.2.2
New Fixes/Features:
Fixed issue with LAN Boot order list.
Fixed issue with S5 wake from USB keyboard/mouse.
Fixed issue where items disappear from Boot menu.
Fixed issue where USB cannot wake system from S5.
Fixed issue where "UEFI: USB: USB Entry for Windows To Go" is sometimes shown in Legacy Boot Priority.
Fixed issue where Event logo shows “Flash update failed (1)”.
Updated GOP to version 7.1.1005.
Updated VBIOS to version 1007_20141009.
Added support for Linux* OS installation.
Removed USB2.0 support setup item.
Changed [xHCI mode] to [USB3.0 (xHCI mode) support].
Created [OS selection] setup item, and default as “Windows 8.X”.
Fixed issue with USB Legacy function.
Fixed issue with Hard Disk Drive Password valid characters length.
Fixed Express BIOS Flash update issue.
Fixed issues with Unknown Devices in Windows 7*.
Fixed issue with Linux installation.
Fixed issue where system hangs at POST code 67.
Fixed issue with VGA Cable output.
Fixed issue where “Keyboard ready beep” option does not work.
Added support for Intel® Integrator Toolkit.
Fixed issue where BIOS update cannot change setup default.
Fixed issue where Unlimited Boot to Network Attempts option does not work.
Fixed issue where disabling VT fails.
Fixed issue where system does not boot if EFI boot is disabled.
Fixed issue where 19V adaptor warning message is triggered.
Fixed issue with Legacy USB Key (DOS) detection.
Enabled UEFI and Legacy Boot so both can be enabled.
Added support for more DMI information on System/Board Information page.
Fixed issue where DMI tool cannot be used in DOS.
Fixed issue where Boot Menu shows unnecessary UEFI LAN Boot item.
Fixed issue where monitor is blank if both UEFI and Legacy Boot are enabled.
Fixed issue where Bootable Device Not Detected Function Test fails if both UEFI and Legacy Boot are enabled.
Fixed issue where USB keyboard does not work.
Fixed issue with USB device compatibility.
Fixed issue where system hangs at POST code 32 after S3 resume.
Fixed issue with Fast Boot.
Fixed issue with incorrect Hard Disk Drive passwords.
Fixed issue with BIOS passwords.
Known Errata:
Some USB keys cannot be detected in BIOS Recovery mode. Format the USB key before Recovery.
In Windows 7, the system will auto wake up after S5 if a USB key is connected.
Information about HDMI monitor and HD Audio does not show up in Playback under Sound properties in Control Panel if Legacy Boot is enabled in BIOS. Workaround: disable Legacy Boot in BIOS Setup.
BIOS Version 0015 - FYBYT10H.86A.0015.2013.1210.1722
About This Release:
Date: December 10, 2013
Integrated Graphics
Option ROM: Build 1004 PC 14.34
GOP Driver: 7.0.1029
LAN
UEFI Driver: 2.0.23
Visual BIOS: 2.2.2
New Fixes/Features:
Initial production BIOS release
LEGAL INFORMATION
Information in this document is provided in connection with Intel Products and for the purpose of supporting Intel developed server/desktop boards and systems.
No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document. Except as provided in Intel's Terms and Conditions of Sale for such products, Intel assumes no liability whatsoever, and Intel disclaims any express or implied warranty, relating to sale and/or use of Intel products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright or other intellectual property right. Intel Corporation may have patents or pending patent applications, trademarks, copyrights, or other intellectual property rights that relate to the presented subject matter. The furnishing of documents and other materials and information does not provide any license, express or implied, by estoppel or otherwise, to any such patents, trademarks, copyrights, or other intellectual property rights. Intel products are not intended for use in medical, life saving, or life sustaining applications. Intel may make changes to specifications and product descriptions at any time, without notice.
Intel is a trademark of Intel Corporation in the US and other countries.
Copyright © 2014 Intel Corporation.
I use the 038 bios but bios is not in full screen on my Samsung LCD TV.
Any ideas?
