fritsch, i tried your version but no help for me with my NUCs: i have a strange problem playing some .isos with 5.0 beta1, some (random?) next movie in the same directory starts playing in the backround.
The .isos play just fine with 4.2.1
Unfortunately the issue is still present.
If I navigate the menus really slow giving it time between key presses it doesn't happen.
Okay, then you really have a remote issue, which is not my part of the my code. When you report that issue make sure that you provide all the relevant logfiles that is needed to track it down.
(2014-11-07, 17:58)xbs08 Wrote: [ -> ]Just updated to OpenELEC 4.95.1. Helix Beta 1 last night and i'm getting remote key presses issues.
It's like the NUC pauses/hangs for one or two seconds but keeps registering key presses on the remote and then executes them all in a quick sequence.
Really weird...
Anyone seeing this on OE 4.95.1.?
Maybe you are not alone?!
http://openelec.tv/forum/120-news-announ...=15#121784
What the last stable build recommend for flash?
If planning on only using for XBMCbuntu, is it worth trying to pick up the updated 2830 over the 2820? Nowhere seems to adbertise if they are shipping the newer 2830 but more recent amazon orders seem to be the 2830, but it can be picked up £20 cheaper from TranquiPC advertised as the 2820.
What is the difference, and is it applicable to linux/xbmc use?
Where is instruction for flashing openelec first time?Thanks.
(2014-11-08, 13:29)xbs08 Wrote: [ -> ] (2014-11-08, 09:00)dwane3 Wrote: [ -> ]What the last stable build recommend for flash?
4.2.1
I had problems, with 4.2.1, the only one that can go sleep and wake up, and use USB is 4.0.7. It wan't even alvailable, so I had to build it myself.
Is 4.95 better, beside the remote controller issue?
