2014-02-08, 05:08
I know you probably heard this already... Though save yourself the hassle and get a Flirc - the money goes to a good cause as well!
(2014-02-08, 05:22)Speedst3r Wrote: [ -> ]I've read through the thread and just want to confirm for the DN2820FYKH:
- 23.976 is fixed (saw a screenshot and mode output on OE forum)
- DTS-HD and TrueHD passthrough works
- The maximum bitrate for hardware h.264 decode before dropping frames (e.g. does Samsung Oceanic Life 40Mbps play without drops)
I can provide a link to Oceanic Life via PM for someone to test if required.
The price for the i3 in Australia is nearly double the Celeron! (AUD$199 vs $389) so if the Celeron can do the above I will be getting two to replace my XIOS boxes!
(2014-02-07, 21:45)pjtpjt Wrote: [ -> ](2014-02-07, 20:24)SgtSlaughter Wrote: [ -> ]When I enter the BIOS the Visual BIOS is blank.
I am one step away from a RMA with Intel support.
The upgrade corrupted my POST and Visual bios outputs. I am also having issues with my HDMI aligning on 4 different televisions.
I cannot recommend Intel dn2820fyk for media center.
I'm sorry you had bad luck with your device, but so far I haven't seen many people complaining about it. I've received mine yesterday, and since I have updated the BIOS, installed Linux Mint Petra, XBMC, even Portal on Steam, and haven't had any problems. I've played with it for hours.
Next I'm gonna try Android x86 for sheer fun.
Quote:We were able to stream 720p and 1080P content flawlessly for the most part. Our mkv 720p/1080p and mkv 1080p dts-hd files played without stutters or any audio issues, so we were pretty happy. If you have a bunch of 1080P content ~20Mbps DTS, but it does struggle with 1080p Hi10P w/ FLAC audio, which is sort of the 800 pound gorilla in the room in terms of newer standards that are pushing the limits of hardware requirements.
Read more at http://www.legitreviews.com/intel-nuc-dn...WsqJKro.99
(2014-02-08, 05:33)nooryani84 Wrote: [ -> ]Sorry, I meant if someone who already has a DN2820FYKH could confirm those bullet points(2014-02-08, 05:22)Speedst3r Wrote: [ -> ]I've read through the thread and just want to confirm for the DN2820FYKH:
That's impressive!
(2014-02-08, 07:27)nooryani84 Wrote: [ -> ]Knowing Intel, these issues will most likely be ironed out.
(2014-02-08, 09:13)Crssi Wrote: [ -> ](2014-02-08, 07:27)nooryani84 Wrote: [ -> ]Knowing Intel, these issues will most likely be ironed out.
Yeah right. You mean in a year... or two... or maybe.
https://communities.intel.com/message/22...irect=true
(2014-02-08, 12:02)Geekzilla Wrote: [ -> ]I received my Bay Trail NUC this evening and quickly set it up. Hopefully this can reassure people of it's capabilities. Click the links for evidence.Thanks for that! When you are playing a video with 23.976 FPS are you having the refresh rate match the video? What is the output of codecinfo? Just realised Oceanic Life is 29.97 fps. Any of the "23.98" files from http://www.demo-world.eu/trailers/high-d...ailers.php can be used to test 23.976.
Oceanic Life skipped 1 frame on the initial bootup and then played through the entire folder without any skipped or dropped frames.
This was on a hastily setup unit running version 0021 of the bios and openelec nightly "OpenELEC-Generic.x86_64-devel-20140204145610-r17626-g97447e4"
I was able to boot off USB 3.0 stick using instructions from this thread. If the unit boots to a blank screen, keep pressing F2 to get into setup. Another snag I ran into was I was unable to flash the bios from within Visual Bios. Instead I had to press F7 repeatedly at startup before the BIOS screen to get into an old school text based BIOS flash utility which allowed me to update via USB. I am using a Crucial 2GB CT25664BF1339 stick with 512MB allocated for Video in the BIOS. I did remove the wi-fi card, as I only use wired ethernet and find the dual NIC's more trouble than it's worth. I didn't mess with the IR receiver, as I use FLIRC and think that is a superior solution.
I hope than clarifies some questions and I plan to play with it some more this weekend as time allows.
