(2014-01-20, 18:45)jjd-uk Wrote: [ -> ]Are you sure it's not in the driver bundle?
Not that I can see. I just rechecked twice.
(2014-01-20, 18:50)chaseme Wrote: [ -> ]To the guy's who've gotten one. Does it require the power cable from the socket to the PSU block like other NUCs?
The power cable is included if that's what you're asking..
(2014-01-20, 19:05)snatch22 Wrote: [ -> ] (2014-01-20, 18:45)jjd-uk Wrote: [ -> ]Are you sure it's not in the driver bundle?
Looking here
https://downloadcenter.intel.com/SearchR...+DN2820FYK
I don't see it either.
You'll have to ask Intel, maybe they are deliberately not providing the driver so forcing you to get a higher end NUC if you want HD audio.
Use
http://www.intel.com/support/graphics/sb...ine+driver to check that it's not installed, as maybe it is bundled in one of the other drivers.
1.5.1.3.1 Integrated Audio Provided by the HDMI Interfaces
The following audio technologies are supported by the HDMI 1.4 interfaces directly
from the SoC:
• AC-3 - Dolby* Digital
• Dolby Digital Plus
• DTS-HD*
• LPCM, 192 kHz/24-bit, 8 Channel
Yup, I also read that. Doesn't work at the moment though. Also couldn't find the * explanation...
Thanks for the update on the power cable Snatch!
In regards to RAM, I'm confused on the volts. Can this take 1.5V DIMMS or it's 1.35v only?
Is there any word on an Atom NUC?
Would there be any advantage in waiting for Atom?
(2014-01-22, 10:56)rogerthis Wrote: [ -> ]Is there any word on an Atom NUC?
This celeron nuc, DN2820FYK, is a renamed atom, based on bay trail.
You will not see a atom nuc, perhaps a haswell based celeron, like 2955u
(2014-01-22, 17:14)snatch22 Wrote: [ -> ]Thanks for your continued assistance, but no dice. Says unsupported. Intel also doesn't seem to be of much help... this is my thread on the forums there: https://communities.intel.com/message/220509. Not sure if I should pursue a refund or wait it out and hope they fix it..
Have you tried out openelec?
Wow, that's really disappointing if DTS-HD isn't supported by this guy. Maybe I'll have to go with one of the i3 NUCs.
Good luck and please keep us posted.
(2014-01-22, 18:57)rogerthis Wrote: [ -> ] (2014-01-22, 17:14)snatch22 Wrote: [ -> ]Thanks for your continued assistance, but no dice. Says unsupported. Intel also doesn't seem to be of much help... this is my thread on the forums there: https://communities.intel.com/message/220509 Not sure if I should pursue a refund or wait it out and hope they fix it..
I have very little experience with linux in general and before I installed the SSD I attempted to get openelec running on a USB stick, but I couldn't get it to boot from the live stick according to the directions on the openelec wiki.. I *think* it has something to do with the uefi bios but this system is for someone else so I wanted to get windows on and I didn't try too hard. I suppose I could look into it more..
