2014-03-10, 22:35
I've been using CT51264BF160B in my NUC for a couple weeks now. When I get home I'll tell it it's not compatible...
http://www.crucial.com/store/partspecs.a...1264BF160B
(2014-03-10, 16:07)xbs08 Wrote: [ -> ]Crucial Memory Advisor Tool says this module is not compatible.I believe the reason for the CT51264BF160B not being on the list of compatible memory (there will always be much more working sticks than those on the list) - is due to some earlier intel nuc's with 2 slots have had issues running these as a set. Most reports indicated that either using just one stick, and/or manually setting up timing and voltage for the stick (for those nuc's supporting both 1.5v and 1.35v) - cleared the issue right up.
This part CT51264BF160B is not compatible.
View compatible parts for the DN2820FYK.
Can anyone confirm this??
(2014-03-10, 18:37)Crssi Wrote: [ -> ]Expect the F2 entering BIOS problem resolution in forthcomming BIOS over next few weeks.Sounds great! May I ask your source of this?
(2014-03-11, 10:38)ozimek Wrote: [ -> ]I got this NUC a couple of weeks ago, but I'm having some issues. Win 8.1 doesn't seem to recognize my receiver properly. It is a Marrantz NR1403, which does have support for DTS-HD MA etc.
(2014-03-11, 00:01)pr0xZen Wrote: [ -> ](2014-03-10, 16:07)xbs08 Wrote: [ -> ]Crucial Memory Advisor Tool says this module is not compatible.I believe the reason for the CT51264BF160B not being on the list of compatible memory (there will always be much more working sticks than those on the list) - is due to some earlier intel nuc's with 2 slots have had issues running these as a set. Most reports indicated that either using just one stick, and/or manually setting up timing and voltage for the stick (for those nuc's supporting both 1.5v and 1.35v) - cleared the issue right up.
The CT51264BF160B is also double sided - I believe the CT51264BF160BJ is single sided. In extreme conditions, it might be a very tight fit for 2 overlapping slots.
I'm expecting delivery tomorrow, and I too have the CT51264BF160B lying ready. Can't imagine there being any real problem, but I'll let you know if so happens
(2014-03-11, 10:38)ozimek Wrote: [ -> ]The graphics(&audio) driver should be the newest one from Intel:Have you tried with the drivers dated 02/20/2014 ?
(2014-03-11, 14:58)pr0xZen Wrote: [ -> ]Think you maybe getting confused, there was an issue of people not getting any audio over HDMI with Win 8.1 in legacy mode and that is indeed resolved by having UEFI enabled, however there has been no case of either DTS-HD or TrueHD working on Windows due to the missing IME driver which is needed by a Intel & Windows combination for Protected Audio Path (PAP1.5) to work.(2014-03-11, 10:38)ozimek Wrote: [ -> ]The graphics(&audio) driver should be the newest one from Intel:Have you tried with the drivers dated 02/20/2014 ?
https://downloadcenter.intel.com/Detail_...h&lang=eng
(Not sure if linking works here, but if not you'll find them on the Intel site - just search for DN2820FYKH)
Edit: Ah, it seems this might be a larger issue. I do however, seem to have read some people getting HD audio in win8(.1) by making sure UEFI is enabled and Legacy is disabled, in BIOS: And some reported that this had to be set during OS install - changing it afterwards wouldn'y cut it...(?) I might be way off - but I do believe I read this. And likely here in this thread.
(2014-03-11, 10:50)nickr Wrote: [ -> ]Screenshot of xbmc audio settings please.
(2014-03-11, 10:56)jjd-uk Wrote: [ -> ]Thanks for digging that up! That seems to be the key. I just spent ages creating a profile for those forums to be able to join the nagging choir(2014-03-11, 10:38)ozimek Wrote: [ -> ]I got this NUC a couple of weeks ago, but I'm having some issues. Win 8.1 doesn't seem to recognize my receiver properly. It is a Marrantz NR1403, which does have support for DTS-HD MA etc.
The problem is that Intel have so far failed to provide the required Intel Management Engine driver to get DTS-HD working on Windows, currently the only way to get DTS-HD is via the Linux OS with a distro such as Openelec.
If having this working on Windows is important to you complain at https://communities.intel.com/thread/481...0&tstart=0
(2014-03-11, 15:47)jjd-uk Wrote: [ -> ]Think you maybe getting confused, there was an issue of people not getting any audio over HDMI with Win 8.1 in legacy mode and that is indeed resolved by having UEFI enabled, however there has been no case of either DTS-HD or TrueHD working on Windows due to the missing IME driver which is needed by a Intel & Windows combination for Protected Audio Path (PAP1.5) to work.
(2014-03-09, 12:16)xbs08 Wrote: [ -> ]After reading the long thread still haven't find how the DN2820 compared to the 1007U?Perf. level little bit higher than Celeron 847- at least with Windows as for today.
Anyone that used both can help?
