2014-02-25, 17:09
For a long time I have been wanting to clean up the language strings for reFocus. Over time it has really become quite an unorganized mess.
As XBMC (and many, if not most, skins) have switched to using Transifex for the editing and managing of translations I will be doing the same for reFocus.
The english source language file for reFocus is available at the Transifex project page
The upcoming Gotham release of reFocus will likely still use the old (but updated) strings.xml language file. This is because I have also changed the ID's of the strings, which I now have to go change in all the .xml files the skin uses. That will take some time and testing. I do consider it a priority though, so if it will not be included in the Gotham release, it will be shortly after that.
If you want to contribute, you can register at Transifex if you aren't already and request to be a translator for your language(s). I am not expecting to make major changes to the source.
More information about the translation system can be found here
If you have any questions don't hesitate to ask. I am still getting acquainted with the system too though
