(2014-03-14, 09:10)negge Wrote: [ -> ]No it should still work. I had that problem once or twice myself, it seems enabling "asynchronous EPG" from the addon settings fixes it.
That seemed to fix it. Thanks! Maybe that setting shouldn't really be there (or atleast needs a different default)
~Jess
There's some bugs when it comes to EPG handling that still need to be ironed out.
anyone have an openelec build of the addon?
openlec 3.95.1 is very unstable for me using 3.4.27 with lots of xbmc restarts
(2014-03-14, 14:21)negge Wrote: [ -> ]Windows build available at:
http://werket.tlk.fi/~negge/pvr.tvh/pvr....elease.zip
It only runs with Gothem, but i did a few tests on my "play & test" system.
To be honest for me it is not predictable or reproducible that happens if i press ff or rw.
I only want to rewind 30s or after a long pause i wand to skip the next advertisement..
Resuming from pause works for the first seconds, but then i have interference, sometimes it calms down after a while but not always.
Also a lot of Picture errors after a rewind and i never know where i am.
I was not able to find a scene in the buffer two times....
But i hope the best for next releases and will continue testing.
BTW: EPG works after i enable asynchronous EPG Transfer.
The EPG issue should be fixed.
@f451: some interference should be expected (more so on h.264 channels) but it should be pretty minimal. And indeed it's hard to know where in the buffer you are as XBMC doesn't support showing it yet.
Someone how has built this for linux 64-bit and would like to share the zip?
(2014-03-20, 23:48)Nafi Wrote: [ -> ]ok try this. it's version 0.4 compiled some minutes ago.
http://www32.zippyshare.com/v/90445313/file.html
This works fine and seems to be latest version. By some reason I still get a message that there are an update available. Do you get that too?
Still some EPG problems. Sometimes EPG screen shows nothing, but after reselecting this item there it is.
Latest XBMC, tvheadend and plugin running on Debian Testing.
Think I'm getting my knickers in a twist here - trying to upgrade to the latest 0.4 that Nafi compiled.
Won't install from zip - says it's the wrong format. So I've replaced the files in the following locations
/usr/local/share/xbmc/addons/pvr.hts/
/usr/local/share/xbmc/addons/pvr.tvh/
/usr/local/lib/xbmc/addons/pvr.hts/
/usr/local/lib/xbmc/addons/pvr.tvh/
But still getting the add-on reported as 1.9.25 - clearly I'm doing something wrong! Can someone straighten me out pls?
(Running Gotham on xbmcbuntu)...
@J3mm: you're changing the wrong files, the installed addons are in ~/.xbmc/addons.
