After upgrade to Mac os x 10.9.2, xmbc switch the screen resolution to lowest and I am not able to see anything. I have Macbook pro 15" with Retina Display.
Same issues here (notice the color gradients how its all choppy)
Heres my
xbmc.log
The temporary fix is to go to Settings > System > Video Output and change display mode from full screen to windowed, then back to full screen. But the problem returns upon opening XBMC again.
OS X Version: 10.9.2
Platform: MacBook Pro 15" mid 2010
Install method: dmg
Skin: Confluence
CPU: 2.4 GHz Intel Core i5
RAM: 4GB 1067 MHz DDR3
Architecture: x86_64
Ok I just realized it may not be the EXACT same issue as the original post, but is there a fix?
Here is the log, and my retina display resolution is set to 1920x1200; however, XBMC switch to 1024x640 and cannot able to see full screen.
22:00:06 T:140735105393424 NOTICE: -----------------------------------------------------------------------
22:00:06 T:140735105393424 NOTICE: Starting XBMC (12.3 Git:20131212-9ed3e58), Platform: Darwin OSX (13.1.0 x86_64, Version 10.9.2 (Build 13C64)). Built on Dec 23 2013
22:00:06 T:140735105393424 NOTICE: special://xbmc/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
22:00:06 T:140735105393424 NOTICE: special://xbmcbin/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
22:00:06 T:140735105393424 NOTICE: special://masterprofile/ is mapped to: /Users/leerob/Library/Application Support/XBMC/userdata
22:00:06 T:140735105393424 NOTICE: special://home/ is mapped to: /Users/leerob/Library/Application Support/XBMC
22:00:06 T:140735105393424 NOTICE: special://temp/ is mapped to: /Users/leerob/.xbmc/temp
22:00:06 T:140735105393424 NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Contents/Frameworks
22:00:06 T:140735105393424 NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
22:00:06 T:140735105393424 NOTICE: Local hostname: leerob-mac
22:00:06 T:140735105393424 NOTICE: Log File is located: /Users/leerob/Library/Logs/xbmc.log
22:00:06 T:140735105393424 NOTICE: load settings...
22:00:06 T:140735105393424 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
22:00:06 T:140735105393424 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:00:06 T:140735105393424 NOTICE: loading special://masterprofile/guisettings.xml
22:00:06 T:140735105393424 NOTICE: Getting hardware information now...
22:00:06 T:140735105393424 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:00:06 T:140735105393424 NOTICE: Loaded playercorefactory configuration
22:00:06 T:140735105393424 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:00:06 T:140735105393424 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:00:06 T:140735105393424 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:00:06 T:140735105393424 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:00:06 T:140735105393424 NOTICE: Default DVD Player: dvdplayer
22:00:06 T:140735105393424 NOTICE: Default Video Player: dvdplayer
22:00:06 T:140735105393424 NOTICE: Default Audio Player: paplayer
22:00:06 T:140735105393424 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:00:06 T:140735105393424 NOTICE: Log level changed to 0
22:00:06 T:140735105393424 NOTICE: Loading media sources from special://masterprofile/sources.xml
22:00:06 T:140735105393424 ERROR: CCoreAudioDevice::SupportsMixing: Device mixing support : 'No'.
22:00:06 T:140735105393424 NOTICE: Running database version Addons15
22:00:06 T:4516966400 NOTICE: Thread XBMC Peripherals start, auto delete: false
22:00:06 T:140735105393424 NOTICE: Setup SDL
22:00:07 T:140735105393424 NOTICE: Display 0 has name Color LCD
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 1440 x 900 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 720 x 450 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 1920 x 1200 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 1680 x 1050 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 1280 x 800 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 1024 x 640 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 840 x 525 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 2880 x 1800 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 2560 x 1600 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 2048 x 1280 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 800 x 600 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Found possible resolution for display 0 with 640 x 480 @ 60.000000 Hz
22:00:07 T:140735105393424 NOTICE: Checking resolution 16
22:00:07 T:140735105393424 NOTICE: GL_VENDOR = NVIDIA Corporation
22:00:07 T:140735105393424 NOTICE: GL_RENDERER = NVIDIA GeForce GT 650M OpenGL Engine
22:00:07 T:140735105393424 NOTICE: GL_VERSION = 2.1 NVIDIA-8.24.9 310.40.25f01
22:00:07 T:140735105393424 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
22:00:07 T:140735105393424 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
22:00:08 T:140735105393424 NOTICE: Running database version Addons15
22:00:08 T:140735105393424 NOTICE: Running database version ViewModes4
22:00:08 T:140735105393424 NOTICE: Running database version Textures13
22:00:08 T:140735105393424 NOTICE: Running database version MyMusic32
22:00:08 T:140735105393424 NOTICE: Running database version MyVideos75
22:00:08 T:140735105393424 NOTICE: Running database version TV22
22:00:08 T:140735105393424 NOTICE: Running database version Epg7
22:00:08 T:140735105393424 NOTICE: start dvd mediatype detection
22:00:08 T:140735105393424 NOTICE: initializing playlistplayer
22:00:08 T:4571738112 NOTICE: Thread CDetectDVDMedia start, auto delete: false
22:00:08 T:140735105393424 NOTICE: DONE initializing playlistplayer
22:00:09 T:4633137152 NOTICE: Thread XBPyThread start, auto delete: false
22:00:09 T:140735105393424 NOTICE: Previous line repeats 1 times.
22:00:09 T:140735105393424 NOTICE: initialize done
22:00:09 T:4634210304 NOTICE: Thread XBPyThread start, auto delete: false
22:00:09 T:4633137152 NOTICE: -->Python Interpreter Initialized<--
22:00:09 T:140735105393424 NOTICE: Running the application...
22:00:09 T:4633137152 NOTICE: service.libraryautoupdate: Update Library Service starting...
22:00:09 T:4633137152 NOTICE: service.libraryautoupdate: update timers
22:00:09 T:4633673728 NOTICE: -->Python Interpreter Initialized<--
22:00:09 T:4634210304 NOTICE: -->Python Interpreter Initialized<--
22:00:09 T:4667740160 NOTICE: Thread Jobworker start, auto delete: true
22:00:09 T:140735105393424 NOTICE: ES: Starting event server
22:00:09 T:4668538880 NOTICE: Thread CEventServer start, auto delete: false
22:00:09 T:4668538880 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
22:00:09 T:4668538880 NOTICE: UDP: Listening on port 9777
22:00:09 T:4669075456 NOTICE: Thread CTCPServer start, auto delete: false
22:00:09 T:140735105393424 NOTICE: starting zeroconf publishing
22:00:09 T:4669612032 NOTICE: Thread Jobworker start, auto delete: true
22:00:09 T:4683878400 NOTICE: Thread CRssReader start, auto delete: false
22:00:09 T:4634210304 NOTICE: StorageServer Module loaded RUN
22:00:09 T:4634210304 NOTICE: StorageClient-2.5.4 Starting server
22:00:09 T:4634210304 NOTICE: StorageServer-2.5.4 Storage Server starting /Users/leerob/.xbmc/temp/commoncache.db
22:00:39 T:140735105393424 NOTICE: Storing total System Uptime
22:00:39 T:140735105393424 NOTICE: Saving settings
22:00:39 T:140735105393424 NOTICE: stop all
22:00:39 T:140735105393424 NOTICE: ES: Stopping event server
22:00:39 T:140735105393424 NOTICE: stopping zeroconf publishing
22:00:40 T:4668538880 NOTICE: ES: UDP Event server stopped
22:00:40 T:140735105393424 NOTICE: stop dvd detect media
22:00:40 T:140735105393424 NOTICE: stop sap announcement listener
22:00:40 T:140735105393424 NOTICE: clean cached files!
22:00:40 T:140735105393424 NOTICE: unload skin
22:00:40 T:4634210304 NOTICE: StorageServer-2.5.4 Closed down
22:00:40 T:140735105393424 NOTICE: stop python
22:00:40 T:140735105393424 NOTICE: stopped
22:00:40 T:140735105393424 NOTICE: destroy
22:00:40 T:140735105393424 NOTICE: unload sections
22:00:41 T:140735105393424 NOTICE: destroy
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
22:00:41 T:140735105393424 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
22:00:41 T:140735105393424 NOTICE: unload sections
22:00:41 T:140735105393424 NOTICE: application stopped...
Read the link again:
debug log (wiki)
Note where says to turn debugging on and to not post logs directly into forum posts.
