Full Version: How does XBMC pick up on what season it is for a show?
Hi...
I am wondering has XBMC perhaps changed how seasons are picked up? Is it perhaps more through the filename or the NFO?
The reason I ask is my seasons are appearing normally like, season 1-13. But they should appear how I set them up in the NFO....
In the NFO they appear like this 1997-2010. Which use to work fine, it would just say Season 1997 etc etc
Is it perhaps now picking it up via the file name?
Thanks for any help!
**edit I just quickly changed the name of all the files for one season and it worked correctly.....This is quite odd! It use to work of NFO data. Is there a way I can change this? Was it XBMC who did it or was it perhaps the skinner? (I'm using Aeon MQ5 atm, before I use MQ4 and/or Aeon Nox)
