Full Version: Installation problems
I get an error:
"The Windows Installer Service could not be accessed. This can occur if the windows installer is not correctly installed. Contact your support personnel for assistance"
I have followed all the Microsoft and top 3 Google results for this issue, and still receive this error. Other programs still instal fine.
My computer is windows 7.
Tested our version (http://tinymediamanager.googlecode.com/f...ll_win.msi) and it worked here.
hmm... seems your windows installer is corrupt somehow?!
Try reinstalling
http://www.microsoft.com/en-us/download/...px?id=8483
(ups - NOT for win7!)
edit:
ok, for windows 7 you should try following:
open the CMD shell as administrator (type "CMD" in windows start menu, do a right click, run-as Admin)
do an "sfc /scannow"
If that does not help, try
Msiexec /unregister
Msiexec /regserver
hth
Myron
Thanks for the help. The scannow found some errors, but still have the same error. the Msiexec has changed the error to
THere is a problem with this Windows Installer package. A Dll required for this install to complete could not be run. Contact your support personnel or package vendor
I am busy creating a portable version (a netinstaller, which does not need to get installed). Would you like to test it?
I could do that for you.
I am completely stumped by this install problem.
try this ZIPped one.
http://s000.tinyupload.com/index.php?fil...7556861073
just extract it somewhere.
Have fun Smile
