2014-03-01, 17:34
Software:
* Arch Linux
* XFCE4
* XBMC 12.3
Cables:
PC <DisplayPort> Monitor
PC <HDMI> AVR
This is my setup which worked perfectly fine until a few days ago after I rebooted. Now the instance I start XBMC my monitor loses its signal and there is no way getting it back except for a reboot. I can hear the XBMC menu sounds and can still control everything, but this is the end of monitor output (both DP & HDMI) until I reboot the whole system - even logging out via SSH or changing to another TTY doesnt bring the signal back.
I tried:
* un-/reinstalling XBMC with various pacman parameters and removed ~/.xbmc and /usr/share/xbmc manually, as well as ~/.config/xfce4/xfconf/xfce-perchannel-xml/displays.xml but the problem still remains.
* changing SCREENMODE in ~/.xbmc/userdata/guisettings.xml to WINDOW instead of DESKTOP
* restoring my old displays.xml and edited a couple of lines just now and then I could start XBMC normally without losing the monitor signal, but after putting the system into suspend and waking it up again there was no signal again (never had that before). From that moment on XBMC starting cuts off the monitor signal again
* ~/.xbmc/temp/xbmc.log doesnt show anything unordinary...
I really am completely out of ideas by now. It's a complete pain to have to reboot EVERYTHING every time I try if I fixed the problem. I hope someone can help me debug this weird issue - according to Google I seem to be the only person in the world to have this problem :|
* Arch Linux
* XFCE4
* XBMC 12.3
Cables:
PC <HDMI> AVR
I tried:
