I cannot seem to login into the youtube addon, and I tried both the gmail account and the plusgoogle.com account (as suggested on the forum).
Any idea?
Thanks, Nir.
Thanks. I tried this and it didn't work...
Is there only one Youtube addon to XBMC? Maybe others solved this bug...
I struggled with that too, changed to youtube plugin beta versions, changed python files, created a google+ account, nothing worked. In the end I went back to the vanilla youtube plugin and followed these directions:
http://forum.xbmc.org/showthread.php?pid...pid1627235
Don't forget to remove your youtube login and password from the settings.xml file when you filled in the necessary fields. Since doing this everything works pretty much flawless on my end.
