Full Version: MCE Remote not working
Good day people,
i've got one headaching problem over here, i updated my HTPC with a little bit of new equipment a couple of months ago. (hardware listed below) now the case is, eversince i've upgraded my hardware my MCE remote (or IR Receiver) is'nt working anny more. so tried installing Windows 7 and ran XBMC from out there, i didn't liked it at all but atleast my remote functioned like it should but now i got some time of and installed XBMCbuntu again.. but after hours and hours of googlesearching i didn't find annything that could work for me. though my Xbox360 Controller does work on plug and play!
This is the onlything that came close enough to try but without succes:
# modprobe -r nuvoton_cir
# echo "auto" > /sys/bus/acpi/devices/NTN0530\:00/physical_node/resources
# modprobe nuvoton-cir
# dmesg | tail -20
Now, the "Echo" says: "no such file or directory" and the "dmesg" tells me this:
Quote:[ 4.675426] [fglrx] Firegl kernel thread PID: 1500
[ 4.675479] [fglrx] Firegl kernel thread PID: 1501
[ 4.675552] [fglrx] IRQ 46 Enabled
[ 4.684816] [fglrx] Gart USWC size:1280 M.
[ 4.684818] [fglrx] Gart cacheable size:508 M.
[ 4.684821] [fglrx] Reserved FB block: Shared offset:0, size:1000000
[ 4.684822] [fglrx] Reserved FB block: Unshared offset:f8fc000, size:404000
[ 4.684823] [fglrx] Reserved FB block: Unshared offset:3fff4000, size:c000
[ 6.045138] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
[ 6.653511] r8169 0000:03:00.0: eth0: link up
[ 6.653607] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.634204] Bluetooth: Core ver 2.16
[ 7.634213] NET: Registered protocol family 31
[ 7.634214] Bluetooth: HCI device and connection manager initialized
[ 7.634215] Bluetooth: HCI socket layer initialized
[ 7.634216] Bluetooth: L2CAP socket layer initialized
[ 7.634218] Bluetooth: SCO socket layer initialized
[ 7.635597] Bluetooth: RFCOMM TTY layer initialized
[ 7.635601] Bluetooth: RFCOMM socket layer initialized
[ 7.635602] Bluetooth: RFCOMM ver 1.11
thats all the sucker does. so here's my Setup:
Mainboard: MSI H81M-P33
CPU: Core I3-4130
Memory: 4GB Corsair Vengeance
SSD: Adata s511 64GB
HDD: WD Red 3TB + WD Green 500GB
IR Receiver: HP Windows MCE usb receiver
PSU: doesn't matter
OS: Xbmcbuntu 12.2
hope you guys can help me! thanks in advance!!!!!
Try plugging the IR receiver into a non-USB3 port Smile I had a similar problem and plugging it into a usb2 port made everything start working magically.
I did plug it in to a USB2 port from the start.
Did you solve this problem? I'm looking at this same motherboard for a new build, but remote functionality is a must.
I wonder if your problem wasn't related to an issue with xhci in linux, http://ubuntuforums.org/showthread.php?t=2203116
I had a problem with this on my last build, solution was to disable xhci in my bios. In the latest release notes for Openelec, it listed that this has been fixed, though I personally haven't upgraded that build yet to see if it worked to resolve.
