Can anyone give a list as to what skins either in WIP or in the skin section that are compatible with Gotham seeing as the Beta 1 was released and there will be a lot of people including myself wanting to upgrade
Aeon MQ5 works great. It has support for the new subtitle functionality. A lot of skins that have a Gotham release don't support the new subtitle functionality yet.
Guys,
I did a fresh install of 13.2 Gotham and I am having major issues installing many add-ons, especially skins. I see the skins listed above as compatible with Gotham but anytime I go to install any from the built in repository they are marked was *Incompatible*. I have also tried to install MQ5 directly from the official ZIP and no dice..
"Dependencies Not Met ... please contact author ... "
Am I missing anything?? Any help would be appreciated!
Thanks in advance guys!
.JL
Yeah, I'm having the same problem. Fresh install of Gotham and all the skins are marked incompatible. I found a zip version of aeon nox compatible with gotham and manually installed it and all the text inside XBMC disappeared. Weird stuff.
Same issue here . I did a fresh install Xbmcbuntu with 13.2 gotham . All the skins are showing as incompatible.
Same issue here, all skins "incompatible" after an upgrade install on Android 4.2.2.
Did a force refresh on all add-ons and everything was fine after. Thanks!
Mine became compatible on their own without me doing anything :-) Go figure.
