Full Version: subtitle language infolabel in stereoscopic video
When playing a 2D movie I am able to use:
PHP Code:
$INFO[VideoPlayer.SubtitlesLanguage
in VideoOSD.xml
When playing a 3D movie, this label will not display for me.
Is this a known issue?
Note that the problem also occurs when playing a 3D movie in 2D mode.
March 2nd nightly
the rendermode of the video/GUI should not have any effect on the infolabels. This label contains the language of the currently applied subtitle, right? The according icon is showing up for me on Confluence in VideoFullscreen.xml
Well, I use it as a suffix on the button in my OSD to enable/disable subtitles.
The code for the button:
PHP Code:
control type="togglebutton" id="603">
width>317</width>
label>$LOCALIZE[31321] ($INFO[VideoPlayer.SubtitlesLanguage])</label>
altlabel>$LOCALIZE[13397]</altlabel>
onback>SetFocus(599)</onback>
onclick>Dialog.Close(VideoOSD,true)</onclick>
onclick>ShowSubtitles</onclick>
altclick>Dialog.Close(VideoOSD,true)</altclick>
altclick>ShowSubtitles</altclick>
    <include>
dialog_ControlCommons</include>
usealttexture>!VideoPlayer.SubtitlesEnabled</usealttexture>
visible>VideoPlayer.HasSubtitles</visible>
control
When playing a 2D movie it will show up fine:
However, on a 3D movie it will only show the brackets in between which the infolabel should appear:
thats wird i dont had that problem
<control type="image">
                    <left>1820</left>
                    <top>1000</top>
                    <width>30</width>
                    <height>30</height>
                    <aspectratio>keep</aspectratio>
                    <fadetime>IconCrossfadeTime2</fadetime>
                    <colordiffuse>white2</colordiffuse>
                    <texture fallback="">special://skin/extras/BigIcons/Subtitle.png</texture>
                    <visible>!IsEmpty(VideoPlayer.SubtitlesLanguage)</visible>
                </control>
                    <left>1820</left>
                    <top>970</top>
                    <width>30</width>
                    <height>30</height>
                    <texture fallback="">special://skin/extras/BigIcons/Speaker.png</texture>
                    <visible>!IsEmpty(VideoPlayer.AudioLanguage)</visible>
                </control>
                    <left>1860</left>
                    <top>970</top>
                    <width>30</width>
                    <height>30</height>
                    <texture fallback="">$INFO[VideoPlayer.AudioLanguage,flags/language/,.png]</texture>
                </control>
                    <left>1860</left>
                    <top>1000</top>
                    <width>30</width>
                    <height>30</height>
                    <animation effect="fade" time="200">VisibleChange</animation>
                    <texture fallback="">$INFO[VideoPlayer.SubtitlesLanguage,flags/language/,.png]</texture>
                </control>
        </control>
Jeroen, does the 3D movie have the language flag set for the subtitle? Or can you provide your current WIP state of the skin? Github doesn't seem to be up2date.
edit: just copied your code snippet into Confluence and it's working just fine
(2014-03-05, 11:32)da-anda Wrote: [ -> ]Jeroen, does the 3D movie have the language flag set for the subtitle? Or can you provide your current WIP state of the skin? Github doesn't seem to be up2date.
lol, I didn't even think of that Tongue
Anyway, yes that was the problem. I'll go hide in a corner now
