Full Version: How to add add-ons
Dear Friends,
Would you please someone help me to know how could I add some new add-ons to the xbmc apk file and re-compile the apk file? I have already copy and past the plugins of the Ifilms to the addons folder on apk files and re-compile it with apk tools but I got plugins error when I want to watch it on TV box and for any other one that I directly install from the xbmc software after that.
Thanks you so much if you could help me with that.
If you wish to redistribute XBMC with changes such as additional add-ons then you should re-compile XBMC and change the name of the program and remove all of the XBMC branding. You should only distribute XBMC as "XBMC" using the un-modified versions from xbmc.org.
Thank you for your answer, how can I download un-modified ver?
