Full Version: Repeat recording - by name or by time
Hello,
I am currently using mediaportal PVR backend. There is a feature which worked great in WMC where you could set a repeated recording to record a show every day around a certain time, but there are other problems I have with WMC so I cannot use it..
This does not happen in mediaportal as it simply records based on the set time, but often shows are not on at exactly the same time every day and the recording is out of sync.
WMC obviously tracks the show by it's title to allow recording around a set time - can anyone confirm the behaviour of Nextpvr - does it set repeat recordings by time only or is there some logic to track a show (e.g. if it started up to an hour either side it would be recorded correctly per the epg).
Thanks for any help..
In NextPVR the exact match time is flexible, http://www.gbpvr.com/nwiki/pmwiki.php?n=...nced#toc94 The default window is +/ 90 minutes.
Martin
