2014-03-05, 15:04
Hello guys
I have vera micasaverde at home and the integration between the XBMC and vera is good
I have bought some speakers and 6 cameras
I have installed the XBMC on a dedicated small pc and made the windows boot to xbmc directly
What i want is to use the xbmc as a media (music) center (play music using airplay or from the local storage) and to Record the cameras to an external hard disk
Is that possible?
Can xbmc do both at the same time? or maybe the PC it self? do u recommend it?
Thanx
Is that possible?
Thanx
