Full Version: Problem with loops
Hi all,
I need your help, I have got a problem with my python script. When I'm pressing on the enter button of the keyboard, the code will keep re-fetching the same values from each XML tag which it will print 5 same values for each tag when there is one value from each tag.
Here's the code:
import xbmc
    import xbmcgui
    import xbmcaddon
    import os
    import urllib2
    import StringIO
    import sqlite3
    from sqlite3 import dbapi2 as database
    from xml.etree import ElementTree
    class Channel:
         def __init__(self):
             self.__display_name = None
             self.__icon = None
             self.__programs = []
         def get_display_name(self):
             return self.__display_name
         def get_icon(self):
             return self.__icon
         def get_programs(self):
             return self.__programs
         def set_display_name(self, value):
             self.__display_name = value
         def set_icon(self, value):
             self.__icon = value
         def set_programs(self, value):
             self.__programs = value
         def del_display_name(self):
             del self.__display_name
         def del_icon(self):
             del self.__icon
         def del_programs(self):
             del self.__programs
         display_name = property(get_display_name, set_display_name, del_display_name, "display_name's docstring")
         icon = property(get_icon, set_icon, del_icon, "icon's docstring")
         programs = property(get_programs, set_programs, del_programs, "programs's docstring")
    class Programme:
         def __init__(self):
             self.__start = None
             self.__stop = None
             self.__title = None
             self.__sub_title = None
             self.__desc = None
             self.__category = []
             self.__credits = []
             self.__icon = None
             self.__episode_num = None
         def get_episode_num(self):
             return self.__episode_num
         def set_episode_num(self, value):
             self.__episode_num = value
         def del_episode_num(self):
             del self.__episode_num
         def get_start(self):
             return self.__start
         def get_stop(self):
             return self.__stop
         def get_title(self):
             return self.__title
         def get_sub_title(self):
             return self.__sub_title
         def get_desc(self):
             return self.__desc
         def get_category(self):
             return self.__category
         def get_credits(self):
             return self.__credits
         def get_icon(self):
             return self.__icon
         def set_start(self, value):
             self.__start = value
         def set_stop(self, value):
             self.__stop = value
         def set_title(self, value):
             self.__title = value
         def set_sub_title(self, value):
             self.__sub_title = value
         def set_desc(self, value):
             self.__desc = value
         def set_category(self, value):
             self.__category = value
         def set_credits(self, value):
             self.__credits = value
             self.__icon = value
         def del_start(self):
             del self.__start
         def del_stop(self):
             del self.__stop
         def del_title(self):
             del self.__title
         def del_sub_title(self):
             del self.__sub_title
         def del_desc(self):
             del self.__desc
         def del_category(self):
             del self.__category
         def del_credits(self):
             del self.__credits
         def del_icon(self):
             del self.__icon
         start = property(get_start, set_start, del_start, "start's docstring")
         stop = property(get_stop, set_stop, del_stop, "stop's docstring")
         title = property(get_title, set_title, del_title, "title's docstring")
         sub_title = property(get_sub_title, set_sub_title, del_sub_title, "sub_title's docstring")
         desc = property(get_desc, set_desc, del_desc, "desc's docstring")
         category = property(get_category, set_category, del_category, "category's docstring")
         creditss = property(get_credits, set_credits, del_credits, "credits's docstring")
         episode_num = property(get_episode_num, set_episode_num, del_episode_num, "episode_num's docstring")
    class Credits:
         def __init__(self):
             self.__type = None
             self.__role = None
             self.__name = None
         def get_type(self):
             return self.__type
         def get_role(self):
             return self.__role
         def get_name(self):
             return self.__name
         def set_type(self, value):
             self.__type = value
         def set_role(self, value):
             self.__role = value
         def set_name(self, value):
             self.__name = value
         def del_type(self):
             del self.__type
         def del_role(self):
             del self.__role
         def del_name(self):
             del self.__name
         type = property(get_type, set_type, del_type, "type's docstring")
         role = property(get_role, set_role, del_role, "role's docstring")
         name = property(get_name, set_name, del_name, "name's docstring")
    class MyClass(xbmcgui.WindowXML):
         def __new__(cls):
             return super(MyClass, cls).__new__(cls, 'script-tvguide-mainmenu.xml', ADDON.getAddonInfo('path'))
    def onInit(self):
        pass
    def load_channel(self, elem):
             channel = Channel()
             for elem in elem.getchildren():
                 if elem.tag == 'display-name':
                     channel.set_display_name(elem.text)
                 elif elem.tag == 'icon':
                     channel.set_icon(elem.attrib['src'])
             return channel
         def load_programme(self, elem):
             programme = Programme()
             programme.set_start(elem.attrib['start'])
             programme.set_stop(elem.attrib['stop'])
                 if elem.tag == 'title':
                     programme.set_title(elem.text)
                 elif elem.tag == 'sub-title':
                 elif elem.tag == 'desc':
                     programme.set_desc(elem.text)
                 elif elem.tag == 'category':
                     categories = programme.get_category()
                     categories.append(elem.text)
                 elif elem.tag == 'episode-num':
                     programme.set_episode_num(elem.text)
                 elif elem.tag == 'credits':
                     creditss = programme.get_credits()
                     creditss.append(self.load_credits(elem))
                     programme.set_icon(elem.attrib['src'])
             return programme
         def load_credits(self, elem):
             creditss = Credits()
                 if elem.tag == 'actor':
                     creditss.set_name(elem.text)
                     creditss.set_type('actor')
                 elif elem.tag == 'presenter':
                     creditss.set_type('presenter')
                 elif elem.tag == 'director':
                     creditss.set_type('director')
             return credits
    def onAction(self, action):
    if action == ACTION_ENTER:
        #OPEN THE XML SOURCE
        url = ADDON.getSetting('ontv.url')
        req = urllib2.Request(url)
        response = urllib2.urlopen(req)
        data = response.read()
        response.close()
        profilePath = xbmc.translatePath(os.path.join('special://userdata/addon_data/script.tvguide', ''))
       if os.path.exists(profilePath):
           profilePath = profilePath + 'source.db'
           con = database.connect(profilePath)
           cur = con.cursor()
           cur.execute('CREATE TABLE programs(id TEXT, channel TEXT, title TEXT, start_date TIMESTAMP, end_date TIMESTAMP, description TEXT)')
           con.commit()
           con.close
           tv_elem = ElementTree.parse(StringIO.StringIO(data)).getroot()
           channels = {}
           for elem in tv_elem.getchildren():
            if elem.tag == 'channel':
               channels[elem.attrib['id']] = self.load_channel(elem)
               for channel_key in channels:
                   channel = channels[channel_key]
                   display_name = channel.get_display_name()
                   print display_name
                   cur = con.cursor()
                   if not display_name in cur:
                      cur.execute("INSERT INTO programs(id, channel)" + " VALUES(?, ?)", [display_name, 0])
                      con.commit()
                      cur.close
                      print 'Channels store into database are now successfully!'
I guess the problem must be somewhere in this code:
               print display_name
               cur = con.cursor()
                  con.commit()
                  cur.close
Here's the xml file:
<?xml version="1.0" encoding="UTF-8" ?>
    <tv generator-info-name="www.timefor.tv/xmltv">
            <channel id="www.timefor.tv/tv/162">
                <display-name lang="de">ARD DE DE</display-name>
                        <icon src="http://static.timefor.tv/imgs/epg/logos/ard_big.png" />
            </channel>
            <channel id="www.timefor.tv/tv/1">
                <display-name lang="dk">DR1 DK DK</display-name>
                        <icon src="http://static.timefor.tv/imgs/epg/logos/dr1_dk_big.png" />
            </channel>
            <channel id="www.timefor.tv/tv/130">
                <display-name lang="no">NRK1 NO NO</display-name>
                        <icon src="http://static.timefor.tv/imgs/epg/logos/nrk1_big.png" />
            </channel>
            <channel id="www.timefor.tv/tv/135">
                <display-name lang="se">SVT 1 SE SE</display-name>
                        <icon src="http://static.timefor.tv/imgs/epg/logos/svt1_big.png" />
            </channel>
            <channel id="www.timefor.tv/tv/10769">
                <display-name lang="en">BBC One UK EN</display-name>
                        <icon src="http://static.timefor.tv/imgs/epg/logos/bbcone_big.png" />
            </channel>
            <channel id="www.timefor.tv/tv/10214">
                <display-name lang="en">National Geographic Channel UK EN</display-name>
                        <icon src="http://static.timefor.tv/imgs/epg/logos/nationalgeographicchannel_fr_big.png" />
            </channel>
            <channel id="www.timefor.tv/tv/10847">
                <display-name lang="en">Discovery Channel UK EN</display-name>
                        <icon src="http://static.timefor.tv/imgs/epg/logos/discoverychannel_big.png" />
            </channel></tv>
And here's the logs: http://xbmclogs.com/show.php?id=144672
I want to fetch one value from each tag without re-fetching.
Do you know how I can fetch one value from each tag without re-fetching the same values over and over?
24 hours and no one is reply. Does anyone know how I can fetch one value from each XML tag without keep re-fetching the same value over and over??
