2014-03-07, 23:07
Hello,
I have no idea if it's xbmc, ffmpeg or anything else issue/bug. But behaviour like this is unacceptable. I use xbmc Gotham Beta1 on Linux for watching live tv. If signal is good - everything works fine. But bad dvb-t signal (in this case, stream is corrupted) causes xbmc to hang immediatelly. I need to restart my computer or kill -9 xbmc.bin.
I just noticed. that earlier Gotham versions (for example, Alpha1) don't have this issue - of course, if video (or live tv stream) is corrupted, there are pixels/green pixels etc on screen, but there are no issues with xbmc itself (no any hangs etc.).
This is xbmc debug log while playing sample corrupted stream:
http://pastebin.com/MgbaSx6q
To reproduce issue:
- Enable vdpau
- Enable deinterlace - Temporal/Spatial or any other (with deinterlacing disabled, no hangs and everything works as should- strange)
- Try to play this file: https://mega.co.nz/#!TQF0wTyI!nIfHTbZtgV...IWF1ahQy5w (this is sample recorded from tv)
You will notice xbmc completly hanged after a few seconds. Earlier Gotham doesn't have this issue, it seems to be introduced in beta1?
Of course, I'm not asking for corrupted stream like this to be played without interrupts. But xbmc should not hang on them. Currently, every interference of tv signal causes my PC to hang because of xbmc and I need to hard reset (or login via ssh to kill xbmc) and it's really annoying. Can you look at this issue? Thanks.
To reproduce issue:
- Enable vdpau
