Full Version: LIRC problems with Apple remote on Intel NUC (Haswell)
Hellos,
So my problem is more or less that I am not sure how to fill out the hardware.conf.
The driver i am using is nuvoton-cir, which also makes the IRC on the Intel NUC able to register my apple remote (a1294). So obviously they communicate with eachother.
HOWEVER, nuvoton-cir is not a registered driver on the lirc list of compatible drivers/devices (I look through another forum, and I'm pretty sure it is the right driver that is loading. Others have done the same, and I also have a script that loads the driver for the IRC on NUC on each bootup).
My question is though, how do I fill out my hardware.conf properly? I've been able to create a lircd.conf for my remote, but it only list the inputs as "raw code". Which I don't seem to see on other guides within this topic.
Some of my info:
$ cat /proc/bus/input/devices
Quote:I: Bus=0019 Vendor=1050 Product=00c3 Version=0033
N: Name="Nuvoton w836x7hg Infrared Remote Transceiver"
P: Phys=nuvoton/cir0
S: Sysfs=/devices/pnp0/00:08/rc/rc0/input9
U: Uniq=
H: Handlers=kbd event9
B: PROP=0
B: EV=100013
B: KEY=fff 0 200108fc32e 237605100000000 0 700158000 419200004001 8e968000000000 10000000
B: MSC=10
$ ir-keytable -d /dev/lirc0
Quote:Found /sys/class/rc/rc0/ (/dev/input/event9) with:
Driver nuvoton-cir, table rc-rc6-mce
Supported protocols: NEC RC-5 RC-6 JVC SONY SANYO LIRC other
Enabled protocols: LIRC
Repeat delay = 500 ms, repeat period = 125 ms
Should the enabled protocols even be LIRC, or should I use RC-6 (or a third option)?
Many thanks in advance, for anybody willing to assist! Smile
