2015-02-27, 06:09
2015-02-27, 09:51
Are there any full episodes on the WGN site, I can't see any.
2015-03-05, 12:13
Update message
version 1.2.1
* fix Marvel Kids for library export
* fix for quality selections
* fix DNS connection issue
* stabilize proxy connection
* fix CW
* fix NBC Classics
* fix common problems
2015-03-07, 16:08
There is some problem appeared quite recently, I can't open USTV VoD addon at all, updated it, but nothing happens, it just blinks and not opening. Anyone could suggest how to solve this problem? Thanks
2015-03-07, 20:38
I just tried to install USTV VOD v1.2.0 and get a "Script error". I am using Windows 8.1 ... other suggestions in this thread do not work. Any thoughts
Wayne
Wayne
2015-03-09, 05:18
Hey guys!
Can someone please tell me why I can't play TCM movies?
I click the link for the movie that I want to see and I see the "OPENING STREAM" then PLAYBACK FAILED ONE OR MORE ITEMS FAILED TO PLAY. CHECK THE LOG FILES FOR DETAILS.
Any suggestions?
Mikeinstlouis
Any suggestions?
Mikeinstlouis
2015-03-11, 02:29
Awesome plugin, I use it daily! Thanks for your hard work!
Two issues I'm wondering if anyone can help with:
1 - Conan doesn't pull up an Episode list (under TBS). Can this be fixed?
2 - Can Bloomberg TV be added as a station? Specifically, looking for Charlie Rose -- they stream at http://www.charlierose.com/
2015-03-11, 04:28
Now that "Powers" is out, I hope FX streaming gets coded soon.
2015-03-11, 04:54
MSNBC still doesnt work, love the addon though. Thanks.
2015-03-11, 10:35
Remember we have a support thread, if you are getting errors post a log. Latest is 1.2.1 make sure you have installed from the repo or you may get dependency errors.
FX is done but all full episodes won't work without provider login which we don't support.
I said MSNBC is not on it's way, not released because it's dependant other stuff I'm working on.
2015-03-11, 17:35
National Geographic on USTV VoD is not working... I mean, just see the program list but as soon as you try to watch any of them it just crashes.
How Can I solve it.
How Can I solve it.
2015-03-11, 20:05
Where can we go for help?
It seems that this is a place to post problems, but I have not seen any solutions.
2015-03-11, 20:37
Actually this is a thread for release updates, there is a support thread. I answered your TCM question there.
There is actually a work around for that, most problems just require coding so the solution is a new release, some fixes are more complex than others.
2015-03-11, 23:29
Quick question - does this add-on also work on Android (more specifically, Amazon Fire TV) builds? I think add-ons are more or less platform independent, but want to make sure as I'm getting ready to migrate from ATV2 to a Fire TV.
2015-03-11, 23:42
Yes, at the current version at least we seem to it issues ever so often, then release a fix.
