Full Version: libblueray.iso problems on android
I just got my new Android TV Box and installed XBMC to play blueray isos from my NAS unit coming from an nfs share. I can play DVD isos just fine but not bluerays. I have enabled logging and logged the errors, it shows a problem with libblueray.iso on line 397:
16:59:35 T:1813195984 ERROR: Unable to load libbluray.so, reason: Symbol not found: load_library(linker.cpp:745): library "libPVROCL.so" not found
16:59:35 T:1813195984 DEBUG: Dll libbluray.so was not found in path
Here is the log link:
http://xbmclogs.com/show.php?id=145337
Any help would be greatly appreciated.
Thank you!
Try with the beta (wiki).
Tried the beta, now it loads the ISO but just plays the sound with no picture. I wonder if it's because these blurays are 1080p and the keedox is set to 720.
Can you run MediaInfo (wiki) on the ISO? It might be encoded with VC-1.
Says it's AVC....
Any ideas?
Honestly I'm not sure. A dev or someone who understands the libbluray stuff (more than I do) would probably need to look at this. I don't have any BR ISOs handy to test with, but I'll see if I can get some time to try that.
